Pealing off laminated shims.
John Illinois
Last Name: Burgett
Post by John Illinois » Sun May 10, 2020 11:00 am
Is there a good way to separate shims ? I alway have difficulty pealing off the thinnest shim. Finger nail,sharp knife?
John
Re: Pealing off laminated shims.
Post by RajoRacer » Sun May 10, 2020 11:02 am
I've used a small Exacto hobby knife before AND a magnifying visor ! I seem to recall reading something about heating up one end to delaminate the adhesive ?
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun May 10, 2020 11:16 am
Yup- Exacto knife.
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Sun May 10, 2020 12:22 pm
Heat a corner with a small lighter to soften the adhesive, then us a sharp blade. I use a utility knife because it has a good handle and supports the blade well, but a single edge razor blade or exacto knife work as well.
Post by Jerry VanOoteghem » Sun May 10, 2020 1:29 pm
I do more than heat the corner. I hold a propane torch near the shim stack until the adhesive, (paraffin?), burns away. They all come part nicely then. You obviously don't want to melt them... ;)
Post by John kuehn » Sun May 10, 2020 4:05 pm
I have good luck with single edge razor blades. That work fine for me.
John Illinois
Last Name: Burgett
Post by John Illinois » Sun May 10, 2020 5:08 pm
Thanks for all the ideas. I will work on some shims tomarrow.
John
Post by Jerry VanOoteghem » Sun May 10, 2020 6:35 pm
A refinement on my suggestion above would be to put a tie wire through the hole and hold the shim over a stove flame, (which in retrospect, is what I actually did).
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Sun May 10, 2020 7:05 pm
I don’t want the whole pack to come apart so I hold it with a pliers a ways from one end. Then hit the end with the torch.
John Illinois
Last Name: Burgett
Post by John Illinois » Mon May 11, 2020 5:13 pm
I had good luck heating the shims with a micro torch. I held one end and heated just the outer layer all over. The outside layer would curl and loosen. They came off one at a time. The forum helps me once again.
John
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Mon May 11, 2020 10:21 pm
Take your soldering gun, hold it on the pack until the top one slides off. Repeat as needed.
Post by Original Smith » Tue May 12, 2020 10:35 am
I have used an x-acto knife too, as well as a single edge razor blade. What I don't like is the shims are usually .003" which is too thick for close adjustments. I have to make my own .001" shims to get the adjustments I want.
