I'm lost on this one, Help.
Jim Sims
First Name: Jim
Last Name: Sims
* REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Post by Jim Sims » Tue May 12, 2020 7:20 pm
Got a engine giving me nightmares. Will not run on all 4. Good compression, good spark but not getting fuel to number 2 cylinder. Any ideas?
Re: I'm lost on this one, Help.
Post by RajoRacer » Tue May 12, 2020 8:38 pm
Intake leak or cracked intake manifold for starters.
Post by Rich Eagle » Tue May 12, 2020 9:04 pm
Stuck Valve?
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Tue May 12, 2020 9:28 pm
Check your intake manifold for obstructions such as a wasp nest. This was the cause of another engine's problem here recently.
Good Luck,
Post by Norman Kling » Tue May 12, 2020 9:42 pm
I don't think it is a wasp nest or other clog in the intake manifold because 1 and 2 share the same intake port. If the intake valve were stuck, I think it would also affect #1 because instead of drawing fuel through the manifold #1 would be taking drawing compression from #2. So if it really is not getting fuel, I think you have a stuck exhaust valve on 2 so that it is drawing exhaust from the manifold instead of fuel. So check the exhaust valve on #2.
Post by RajoRacer » Tue May 12, 2020 10:03 pm
He stated that it had "good compression" - if that's the case, it couldn't be a stuck valve ?
Kerry
Last Name: van Ekeren
Post by Kerry » Tue May 12, 2020 10:35 pm
Had a 3 cylinder T once, good compression, turned out that the adjustable tappet had backed off, if it still has solid lifters then check that the cam still has a lobe.
Last Name: Patrick
Post by jiminbartow » Wed May 13, 2020 1:36 am
When did it start doing this? What did you do to the engine between the last time you remember it running good and now? Jim Patrick
Post by Wayne Sheldon » Wed May 13, 2020 4:30 am
A truly stuck valve will remain open and give no compression. However, a "sticky" valve may "float". It takes a nearly a second to close, which is fast enough to pass a standard compression test, but even at an idle (say about 300 rpm, four cycle motor, 600 cycles per minute), the valve must close in a fraction of a half cycle. Or roughly less than a twentieth of a second in order to have proper compression.And of course much faster at any higher speeds. So you can see how a sticky valve can in fact pass a standard compression test, yet fail in a running engine. Often, the offending valve can be heard by a trained ear at either the carburetor of the exhaust pipe depending upon whether the offending valve is an intake or an exhaust. There is also a test using a stiff piece of paper or a light cardboard held over the end of the exhaust pipe for if it is an exhaust valve. The exhaust gasses should flow out continuously, pushing the paper/cardboard out somewhat steadily. A slightly burned or sticky exhaust valve will cause a momentary "suck-back" causing the paper/cardboard to slap the end of the exhaust pipe. Intake valves are a bit tougher to test, but usually, will cause more running issues with interference with fuel flow to the neighboring cylinder, or even coughing back clear through the carburetor.
bobt
Last Name: Thompson
Post by bobt » Wed May 13, 2020 6:53 am
Check your firing order 1-2-4-3
Jim Sims
First Name: Jim
Last Name: Sims
Post by Jim Sims » Wed May 13, 2020 9:02 am
Well Kerry hit it right on the nose. Intake adjustable lifter loosened and turned in to the point it was not opening the valve.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Wed May 13, 2020 12:02 pm
Glad you found it Jim. I was going to sugest turning the car around and see if it made number 3 cylinder not work. :D
Kerry
Post by Kerry » Wed May 13, 2020 7:45 pm
Glad to be of some help Jim, I'll charge you the same as all my T work and advice, a freebe :D
As a rule when I do re-builds I set the push rods with just a 3/4 turn from bottoming out and set the valve lash/clearance the old way of stem grinding to avoid this from happening.
Happy T'ing ;)
Last Name: Juhl
Post by Oldav8tor » Wed May 13, 2020 8:09 pm
What an outstanding example of online engine diagnosis. It was fun and informative to read.
