I need to make It easier to work on Model T axles
Bill Crosby
Topic author - Posts: 184
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
As I get older I need to make It easier to work on Model T axles. I have used the orange cart for many projects over the last 50+ years. The blue parts are newly made to hold Model T rear axles.
Re: I need to make It easier to work on Model T axles
Super Cool!!! Nice cart setup. Wish I had room for something like that. Get tired working on the floor in what space I can fit the job into.
- Last Name: Strange
Great setup! Sure beats the trash can that I used to support my driveshaft housing. I did cut a hole in a 2x10 and bolted it to my workbench to support the axle housing.
mgarrett
- First Name: Mike
- Last Name: Garrett
- * REQUIRED* Type and Year of Model Ts owned: 1927 Speedster, 1924 Touring
Bill,
You win the Best New Product Award for Model T owners for 2020, hands down!! So when are you going to start production?
StanHowe
- First Name: Stan
- Last Name: Howe
After about the first ten or so Ruckstells I rebuilt I made a similar setup. Handy, Dandy Deal!! I put a little winch on mine to lift them up to the holder bar. Mine is now laying on the iron pile at the ranch. I like yours a lot!
1194668jc
- Last Name: Crespo
- * REQUIRED* Type and Year of Model Ts owned: None! (For now...)
What a genius...
kelly mt
- Last Name: Kelly
Good idea and nice work.
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
Great idea, but .......
Where’s the chair ?
Where’s the chair ?
Will you be able to install the radius rods with the driveshaft already bolted to the housing?
Small drum - Yes - large drum - No.
Bill Crosby
- First Name: Bill
- Last Name: Crosby
Mark, I took the drive shaft tube and radios rods off as usual but re installed the tube to show that the swinging arm works for both horizontal and In the vertical position.
Thank you for all the kind words. I made It to save whats left of my knees and back.
If anyone would like to make there own setup I can supply any or all the blue parts.
Thank you
Bill
Thank you
Bill
Very nice piece of engineering, Bill ! I hear what you're saying about the "ol' knees" problem !
