Front axle?
Wwbbim
Topic author - Posts: 15
- First Name: Jace
- Last Name: Jensen
- * REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Front axle?
So I am confused about 4 different parts on my 1922 roadsters front axle. When I got the old parts, this is how it came assembled. I have redone the parts but am still co fused if they go like that? It is the parts that attach to the front axle spring(where it went when I got it) and attached to the actual axle.[image][image][/image][/image]
- Last Name: Hatch
Re: Front axle?
Where is the coil spring?
Wwbbim
- First Name: Jace
- Last Name: Jensen
Re: Front axle?
Re: Dan Hatch it was separated at the time we took the pictures
Mustang1964s
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Re: Front axle?
Take a look at this thread.
http://www.mtfca.com/discus/messages/25 ... 1339967930
It shows some good close ups.
Wwbbim
- First Name: Jace
- Last Name: Jensen
Re: Front axle?
Thanks Mustang 64‘s that makes a lot more sense
Re: Front axle?
Instructions and a caution. Be careful when installing the spring! If your not going to use the Hasslers you'll need to return the perches to their correct position. Bolts are available from for Lang's.
- Attachments
- 731241.jpg (99.18 KiB) Viewed 2619 times
- 731242.jpg (97.77 KiB) Viewed 2619 times
- 731243.jpg (103.28 KiB) Viewed 2619 times
- 731244.jpg (103.22 KiB) Viewed 2619 times
