Bolt Id
Divcoone
Last Name: Giles
* REQUIRED* Type and Year of Model Ts owned: Speedster
Bolt Id
Post by Divcoone » Fri May 22, 2020 8:13 pm
Who can tell me what this bolt was used for. Pretty sure it’s Model T.
Kerry
Last Name: van Ekeren
Re: Bolt Id
Post by Kerry » Fri May 22, 2020 8:29 pm
Wheel to rim bolt/nut.
Last Name: Humble
Board Member Since: 2006
Re: Bolt Id
Post by Humblej » Fri May 22, 2020 8:57 pm
Demountable rim bolt
Divcoone
Last Name: Giles
Re: Bolt Id
Post by Divcoone » Fri May 22, 2020 9:08 pm
The bolts are 7/16 in diameter. They look too small for a wheel bolt.
Re: Bolt Id
Post by Mark Gregush » Fri May 22, 2020 9:25 pm
T rim bolts are 7/16".
Divcoone
Last Name: Giles
Re: Bolt Id
Post by Divcoone » Fri May 22, 2020 9:29 pm
OK, thank you.
