Halogen Tail Lites
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Halogen Tail Lites
Post by dunoon » Tue May 26, 2020 1:32 pm
Has anyone had experience putting halogen bulbs in tail lights? I was wondering if the 50/5 halogen bulb would get to hot for the cardboard disc in a 26 tail/brake light? Thanks
Re: Halogen Tail Lites
Post by Mark Gregush » Tue May 26, 2020 2:53 pm
I would think it would get too hot in any case cardboard or not. Better besides the original bulb, LED's would be a better choice;
https://www.ledlight.com/6-volt-negativ ... ights.aspx
Google "MTFCA LED"
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Tue May 26, 2020 3:20 pm
LEDs are to Halogens what Netflix is to Betamax!
Post by DanTreace » Tue May 26, 2020 4:41 pm
The halogen bulb won't hurt the cardboard in a '24-'27 tail lamp.
But after a longer nite travel, sure did warp the plastic lens over the glass tea cup :shock:
Post by Mark Gregush » Tue May 26, 2020 5:36 pm
What CP/watt and was it single contact?
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Tue May 26, 2020 7:12 pm
I had the dual function halogens in my 26 tail lights. Yeah, they were bright...but sucked up a ton of watts and amps. And yes, they were hot. I switched to dual function LED bulbs in the tails now and they are plenty bright, run much cooler, and use barely any wattage to operate. Switched out the halogen headlights in favor of LED too. Then I ditched the alternator and went back to generator. Works great.
Post by DanTreace » Tue May 26, 2020 10:08 pm
Mark, yes single contact ,think it was Langs # 6H-20 , 6v 20 watt. No markings as the halogen is potted in ceramic, and I thru away the package.
My guess is its one of the 120 lumen type, or approx. 12 candle power?
Lang's doesn't list C.P. It was a bunch brighter than the typical incandescent #63 tail lamp bulbs.
