Brass brazing rods
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Brass brazing rods
Post by TBones12 » Wed May 27, 2020 4:37 pm
I drilled out the rivets of a 1912 steering gear box and now the hole is too big for the new rivets.
Is buying brazing rods is the answer to filling in the whole with brass and then re-drilling or simply put the small diameter rivet in and fill around it?
Never did this before. Will a home propane torch be hot enough to melt the brass and fill the hole?
Any suggestions?
Thank you in advanced!
First Name: Henry
Last Name: Lee
Re: Brass brazing rods
Post by Henry K. Lee » Wed May 27, 2020 4:55 pm
Not knowing how large you might have over drilled them, I would use some aluminum round stock in a very tight fit and re-drill to the size needed.
Hope this Helps,
Hank
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Wed May 27, 2020 4:58 pm
No on the home torch, you’ll need oxygen/acetylene.
Can you get a larger rivet ?
Post by John kuehn » Wed May 27, 2020 5:00 pm
Use a rod or rivet that will be a good fit for the holes and use that. Nobody would know the difference and you won’t have to braze or fill in anything.
It can’t be that oversized to see a lot of difference I would think.
Did you drill out the rivets completely though the case or just the heads. It would depend how you drilled them out.
TBones12
Last Name: Poane
Post by TBones12 » Wed May 27, 2020 5:30 pm
I drilled the rivet out completely.
I didn't know they made larger diameter rivets. I only looked at what one of our vendors carries.
I'll check google and see about larger diameter rivets.
Thanks for your feedback.
Post by John kuehn » Wed May 27, 2020 5:55 pm
If you have a Ace hardware store near you give them a try. The larger Ace stores have a good selection of rivets and rods. Just a thought.
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Wed May 27, 2020 5:58 pm
If you can't find the rivet you need locally then go to McMaster Carr's website, they've got pretty much everythnig in the way of fasteners and they're fast and reasonable to ship.
TBones12
Last Name: Poane
Post by TBones12 » Wed May 27, 2020 6:06 pm
Do you think putting the smaller diameter rivet in place and filling the area around it with JB weld would hold, or might the JB crack?
I'll also try McMasters.
Post by Scott_Conger » Wed May 27, 2020 7:26 pm
Take it to a friend who owns a lathe and custom fit what you need. Making a rivet will not take more than 5 minutes each and will be a perfect, snug fit prior to peening and subsequent soldering. By no means consider using an epoxy.
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Wed May 27, 2020 7:33 pm
I am actually rivoting brackets on fenders and what not with some rivots from Tractor Supply. They come in a mulitpack of probably 100 or so for about 5 bucks.All different lengths. I cut the length off to what I need and then stick em in the hole and pound them good with a piece of steel for a bucking bar
.Seem to be working fine.Seems they are 3/16ths?
Post by Allan » Wed May 27, 2020 8:23 pm
Have custom made brass rivets made to suit the holes you have. That way you can maintain the correct rivet head size.
Before the two components of the steering gearbox are assembled, each piece should be heavily tinned with solder. I like to bolt the two pieces together at this point, and then heat them to flow the tinning so they are sweated together. This gets the solder right in between the two pieces, rather than trying to get it to flow in later.
Then you can pound in the rivets, making sure there is a small countersink inside the gearcase to accept some of the rivet as it is pounded.
Hope this helps.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed May 27, 2020 8:39 pm
The annals of the Model T include instances where the riveted gear case has parted from the column. When that happens you have no steering, which has resulted in serious mishaps. Make sure your re-attachment is robust and sound. No aluminum, no plastic, no glue !
"Get a horse !"
TBones12
Last Name: Poane
Post by TBones12 » Wed May 27, 2020 8:51 pm
Good feedback, thanks!
23ford
First Name: Warren
Last Name: Webb
Post by 23ford » Wed May 27, 2020 10:09 pm
Agree with Allen a friend with a small late can make for you :P
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Wed May 27, 2020 11:44 pm
You definitely do not want to do anything shade tree here. If the upper part of the case separates from the lower part you will have no steering control at all. Either find rivets that will fit or get another gear case that is still tight.
Stephen
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Thu May 28, 2020 3:14 am
I have no experience with the riveted brass gearcases, but would silver solder be a good application here instead of regular solder? I know it's much stronger. Just a thought. Dave
1925 mostly original coupe.
JimDix
First Name: James F
Last Name: Dix
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1921 Coupe
Post by JimDix » Thu May 28, 2020 8:01 am
Big Flats Rivet Co sells brass rivets for steering boxes.
Jim Dix
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Thu May 28, 2020 11:08 pm
By now the repairs have been done but there is a low heat brazing rod available that will melt with a propane torch. I bought a pack of them and they work well just like brazing, but very expensive.
Post by Scott_Conger » Thu May 28, 2020 11:13 pm
Like the original assembly, tin/lead solder and rivets are just fine. Very simple, inexpensive, permanent and long lasting
