Building my pan table
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Tue Feb 26, 2019 7:32 pm
I've been working on these for a few weeks, and it's coming together well. My neighbor made an awesome drilling guide on a scrap piece of 1/2" thick aluminum using CNC equipment; it has the 10 locating pin holes, as well as 5 holes I can use to mark the center reference lines and two for the tail shaft. I've got all of the holes drilled 1/8" right now, hopefully I can use a mag drill this weekend and enlarge them to finished size. What's really cool is I can reuse the drilling template.
I used drill bits as shims to square it up to the table top the way I wanted it, then clamped it and drilled away. There is a guide on the side of the jig, but my table has flame cut edges so the shimming was expected. All in all it's coming along nicely.
Re: Building my pan table
Post by Scott_Conger » Tue Feb 26, 2019 7:48 pm
Fine looking bit of work, Gary. Good for you.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Tue Feb 26, 2019 7:58 pm
Very Nice Gary!
Hank in Tin-A-See
Post by RajoRacer » Tue Feb 26, 2019 10:00 pm
Good start there, Gary ! I took on the same endeavor a number of years ago as the KRW c.c tables are few & far between !
