How to remove the timing gear from the cam?
Mark Nunn
Topic author - Posts: 1267
- Last Name: Nunn
I decided to check, and if need be, clean my oil distribution tube. I’m taking the opportunity to do this while my radiator is out and I wait for my new one. The service manual shows the use of a gear puller to remove the timing gear from the cam. It engages into slots in the gear. I have not taken my timing cover off yet so I don’t know if my gear has slots for a puller.
The gears that are currently sold by the vendors don’t have slots. If I have one of those, how do I remove the gear? Would I need to remove the cam to pull the gear? There isn’t much space around the engine block to hook a puller behind the teeth.
- Last Name: Humble
Re: How to remove the timing gear from the cam?
Pulling the gear while the engine is in car is not for the weak or faint of heart. It is not something you do just to check it out. And putting any gear (new or origional) back on is not really possible while the cam is in the engine. The gear needs to be heated up and driven back on, this should not be done while the cam is in the engine. Unless there is a known problem, let that sleeping dog lie.
Mark Nunn
- Last Name: Nunn
The service manual shows removing the gear and using compressed air to blow out the distribution tube. Maybe I could fish a wire through or behind the gear and into the tube to check for obstructions. I need to remove the timing cover anyway. My timer is not centered very well and I have an alignment tool coming. Or, I could put this on the back burner until my car is roadworthy, which I hope will be this year.
Mark
I bought a '19 which kept losing #1 con rod bearing...had to reshim every 100 miles. While changing bands and hog's head was off, I discovered oil sitting in the funnel. Cotton had clogged it entirely and the poor engine was living on what little oil the silly external mag-post line would supply (thank you mag-post supply!!).
Anyway, time spent "drilling" and plumbing the depths of the oil line from the funnel end finally unplugged the darn thing and it ran oil well when done. My new transmission screen seemed to catch the bulk of the gunk within 2 fairly frequent oil changes. I did not use, though believe it would work well, a speedometer cable and low speed drill.
Or try what John did: http://www.mtfca.com/discus/messages/50 ... 1428587229
This experience taught me to never buy a car without pulling the front/passenger side bolt from the inspection plate and look for LOTS of oil flow out the hole when the car is running to ensure buying a healthy car and not one with lots of hidden bearing problems.
good luck and have fun (!)
Kerry
- Last Name: van Ekeren
The gear is NOT a press fit on the camshaft, no heat is needed or even should be considered to ever use to do so. Drop your generator out and as slowly rotating the crank, with a hammer, tap the gear from the generator hole.
- Last Name: Humble
Oops, your right, the cam gear is not the press fit, its the crank gear that needs heat.
I've never had to heat a crank gear to install - just my press.
GG Gregory
- First Name: GG
- Last Name: Gregory
Not a tuff job, and yes it can be done with the engine in the car...I just replaced one for my buddy and in my Roadster a few months ago.
Duey_C
- First Name: Duane
- Last Name: Cooley
Don't be a bit afraid of wiggling that cam gear off for an oil tube check.
For a cam gear nut wrench, I use an old Indestro 1, 1-1/16 or 1-1/8 wrench that has had the open end offset a bit for a specific job dad had on a building somewhere yet it works great for the cam gear nut.
I believe the suppliers offer us a specific socket or some-such for that nut.
Summer of '16 I sat on a chair after the rad was off (waiting for correct rad & shell mounting parts), pulled the gear cover, gear and found this:
Pulled the muck out, reached in. did it again and then put the air to it. Bloop! It went! I cannot spell the sound the air made thru the oil tube! Cuuhuuhuuhuuhuu? Slur the H's?
Hopefully the new screen caught what came out the other end.
Perhaps a "thing to do, every few" for some engines that are not CLEAN inside.
I use a similar old wrench that has an offset to remove the timing gear. Nothing special but it works. Usually a slight tap going back and forth across the gear will help break it loose. It’s made to have a snug slip fit and not a press fit. The crankshaft gear is a press fit and it’s really tight. Just my take on how to remove the large gear.
John Dow
- Last Name: Dow
Anybody need a Dan McEachern bronze cam gear? Used very little, gear mating surfaces like new. $50 + shipping. PM me if interested.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Mark, Make sure to take advantage of your radiator replacement to inspect/change/install new modern seals in you timing cover! ALSO it's the perfect time to install a lip seal on the front of your crankshaft!!! Google "MTFCA modern crankshaft seal Gene Carrothers" and you'll find lots of info and pictures
1912 Torpedo Roadster
