Why is the crown ignition key worth so much
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Fri Feb 07, 2020 3:03 pm
Looking at all the ignition keys for the Model T I was wondering why the ones with the Crown marking are selling for so much, I also found a few with the letter B, are they worth any more? Bob
Re: Why is the crown ignition key worth so much
Post by Original Smith » Fri Feb 07, 2020 3:23 pm
Bob:
How about a picture! I have over 100 keys on my keyboard! The hooks are all filled to the end, but I don't recall any with a crown. I don't feel like looking either!
FATMAN
First Name: ROBERT
Post by FATMAN » Fri Feb 07, 2020 3:31 pm
Benp
First Name: Benjamin
Last Name: Perfitt
Post by Benp » Fri Feb 07, 2020 3:39 pm
Bob,
If you don’t mind my asking, how much is “so much”?
Kinda caught my attention as I was startled by what original keys for my 1918 non-T are going for. That is, IF they can be found. Problem is, most people don’t have a way to identify them.
We found old barrel keys that could work (if you really play with them).
Ben P.
Benp
Last Name: Perfitt
Post by Benp » Fri Feb 07, 2020 3:46 pm
Guess that eBay link answered that question.
All I can say is, I’d be running like a thief in the night - but am in a different boat.
WOW.
Post by Mark Gregush » Fri Feb 07, 2020 3:54 pm
Guess I should go look at mine! I would be happy to sell one for that price and buy a lower cost one to replace it. :D (except maybe the very first one I got with the 21?
Post by Allan » Fri Feb 07, 2020 7:55 pm
Those were special issue for Canadian Government purchases. Because Canada was part of the British Empire, all government owned property bore the crown logo.
Post by John kuehn » Fri Feb 07, 2020 7:57 pm
So does the crown K mark on the Ford keys have a white brass appearance? The uncut crown K would be the most expensive ones I would think. Didn’t know about the crown keys being a collector key. A new trend in key collecting getting started?
Post by DanTreace » Fri Feb 07, 2020 10:04 pm
Actually the 'crown' logo is for King Lock Co. the maker of that Ford key.
For all the most info in one place on Ford keys, coil box, or ignition switch, we have this nice research ;)
IGNITION KEYS
1913 - 1927
By Trent E. Boggess
Dept. of Business
Plymouth State College, Plymouth, NH 03264
It seems that there is a story in even the simplest, most common Model T part. For instance, take ignition switch keys. A key is a key, right? Just make sure you have the right number. Well, maybe its not so simple.
From the time that the Ford Motor Company began using coils and coil box assemblies of the K.W. Ignition — Ford Motor Company design, the Company began to have a say in the design of the switch keys. The first switch key was adopted for production on April 12, 1913 and was given the factory number T-5815. This key was actually an assembly of three parts: T-5816, T-5817 and T-5823. The handle portion of the key was brass plated. Keys were supplied by both the Clum Manufacturing Co. and the K.W. Ignition Co.
The first real change in this key came on December 19, 1916. The finish on the key was changed from brass plate to Raven Finish. Raven Finish was a rust proofing process that was developed by the Ford Motor Company that was very similar to Parkerizing. It left a black, phosphate coating on the surface of the steel that tended to resist rusting.
On May 8, 1917, the key was redesigned. Instead of an assembly of three pieces, the key was made from a single flat piece of cold-rolled steel. The name of the key was changed as well. Instead of “Switch Lever Assembly,” this part became known as simply the “Switch Key” This design was modified slighTLy on June 19, 1919 by changing the inside corners of the “L” shaped plugs to have a 3/64” radius instead of a square corner to strengthen the dies which made the key.
This key's factory number was changed to T-5815-A on February 13, 1919 to distinguish it from the key used on cars equipped with starters. It remained a part of standard equipment until the use of the switch mounted on the coil box of non-started equipped cars ended about August 9, 1922. Thereafter, this switch key was given the designation T-5815-AR, the “R” indicating that the part was to be used for repairs only. (Releases for T-5815-AR)
The second type of key is distinguishable by the round shape of the head of the key. It was a short lived design supplied by the Clum Manufacturing Company. The tumbler notches appear on one edge of the key only. According to factory records, it was used on the first 15,000 cars built with electric starters in 1919. These cars were primarily sedans and coupes and had the ignition switch and ammeter mounted on the instrument panel. Keys were purchased by Ford in series numbers ranging from 1 to 32. Cars equipped with starters came with two of these keys, as opposed to the non-starter cars which came with only one T-5815-A. The Ford engineering records refer to this key as T-5815-BR and it was given the name “Ignition Switch Key” to help distinguish it from the earlier type. (Releases for T-5815-BR) The final and most common key is characterized by a head that is diamond shaped. While it was adopted on Feb. 21, 1919, the records suggest that this key was not used until after April 23. This key was number T-5815-C. These keys were made out of nickel silver and the heads were “pin frosted” on both sides. A smooth 1/8” by 3/8” surface was provided on the back side of the key for the serial number of the key. These numbers ran from 51 to 74 inclusive. The front face bore the word “Ford” in script.
These keys were made by a number of different vendors. On December 19, 1919 Ford specified that the maker's trademark be placed under the script “Ford” on the face of the key. Keys were supplied by five vendors. These vendors and their trademarks are:
Briggs and Stratton Co.
King Lock Co.
Cabkey Dupree Co (keys have also been observed with Cabkey Dupree spelled out on the key.
Culver Stearns Co.
Cost cutting caused a change in these keys on Jan 16, 1920. The “pin frosting” was eliminated and the front and rear faces of the diamond head became smooth except for the borders, script word “Ford,” trademark, and serial number boss.
The final change to the key came on January 30, 1926 when the material the keys were made from was changed from nickel silver to “S” brass. (Releases for T-5815-C)
Post by DanTreace » Fri Feb 07, 2020 10:11 pm
Examples of 'pin frosted' or stipple finish on the key, others are plain finish .
Briggs and C-D .jpg (100.2 KiB) Viewed 6472 times
Post by Mark Gregush » Fri Feb 07, 2020 10:23 pm
I went back and looked at the list again, must be the King one.
Post by Allan » Fri Feb 07, 2020 10:48 pm
Dang me Dan! Here I was trying to tell a tale and you shot it down.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Feb 08, 2020 9:23 am
I went thru over 150 keys last night. I found one "crown key". King Lock Co must not have made many keyes. About 3/4 of my keys are Ford script. The rest are aftermarket "bogus countrefiet" no name keys :)
Post by John kuehn » Sat Feb 08, 2020 11:48 am
Good information Dan!
It’s always amazing what can be found in the MTFCA encyclopedia.
It’s just another reminder of what can be found on the club website.
Lots of wondering about this and that (myself included) about Model T’s when it can be found at your fingertips.
Post by DanTreace » Sat Feb 08, 2020 1:17 pm
Allan. Sorry about your storytelling ;)
Grouped a few keys. On right is King brand with crown, click image and zoom to see the K inside the crown and others B for Briggs and C-D Capkey-Dupree and more common Diamond mark.
[attachment=1]
Here are two cute ones, owner initialed his well worn Ford key :shock: and odd aftermarket key, marked around the hole ‘Francis Keil and Son New York
