1926 Dash board screws
Topic author - Posts: 1158
- First Name: Robert
- Last Name: Govoni
Is the dash on a 26 Touring held on with flat head bolts and washers that the head of the bolt fits into? Same to hold the steering column?
- First Name: Howard
- Last Name: Tomlinson
Re: 1926 Dash board screws
Nickel plated oval head machine screws. Lang's sells them under "interior screw set". I can't find them locally.
- Last Name: Patrick
We have an old style hardware store here in central Florida called Crowder Brothers that has them. Some Ace Hardware stores have them too, in separate steel boxes in the fastener aisle. Jim Patrick
- First Name: George P
- Last Name: Clipner
And held in place by square nuts on the backside
On our Canadian products I believe there are no cup washers. The panel itself has a raised lip around the holes, and the screws sit in this lip.And, they are Robertson screws wuth the square hole drive.
Allan from down under
- First Name: Kevin
- Last Name: Whelihan
- Board Member Since: 2008
You can get the screws at McMaster-Carr, Seems to me they are 1/4-20 oval head. Forget the length at the moment. Not real expensive.
I personally like stainless steel.
