Anyone use a Model A fuel shutoff on a T?
Topic author - Posts: 6542
There have been lots of discussions about fuel shutoffs but I hadn't seen any reference to those used on a Model A. No idea of thread sizes but some look promising. Has anyone looked into using one of these? The top two don't leak! Not sure about the bottom one.
Re: Anyone use a Model A fuel shutoff on a T?
Perhaps because it's for a Model A?There have been lots of discussions about fuel shutoffs but I hadn't seen any reference to those used on a Model A
ModelT46
- First Name: Darel
- Last Name: Leipold
The top is the one used on the late 1931 that uses the side bowl carb. My 1931 pisckup has the set up/ The lower picture is the used on the side bowl carb.
The Model A fuel shut off has 1/4 PT at the end that screws into the tank. By time you would buy all the parts (new shutoff is 29.95 plus shipping) to install plus a fuel filter you might be in the ball park of a new Model T type sediment bowl anyway. If you have the parts now, you would only need the bushing to install in the tank and would suggest installing pencil type filter.
Rich Huggins
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Hi i purchased a gas shut off valve from one of the top suppliers. Has been on the car about 6 month and it seeps gas i was told to push down wen i turn it off still seeps it is a all brass unit i keep a paper towel on it and change it often there is a water heater in my gauge so i leave the side door open with a floor fan on this helps with the fumes they sell one with a blue knob dose this work better the brass one that i have screws to the carb and looks like it belong,s there what should i replace it with
If you are thinking of using at the carb as a shut off, there would not be space as you would have to use reducing bushing to mate to carb that has 1/8 PT at inlet. Even if the inlet on the carb was the right size, don't think there would be room anyway. If I install any more shut offs at the carb they will be the inline ball type. I would be looking for function not style.
