Connecting rod side play
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Tue Feb 18, 2020 10:55 am
Does anyone know what the rod side play should be on a rebuilt engine that has not been run much ? What is it suppose yo be originally? MEL.
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Re: Connecting rod side play
Post by Mustang1964s » Tue Feb 18, 2020 1:38 pm
Might want to check out Mike Benders youtube videos.
He has one that he installed the connecting rods.
Lot of good information there.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Feb 18, 2020 3:37 pm
Side play varies from crank grinding, a little side play does not hurt anything as long as the rod is straight and in tolerance with the journal, they are made to float in the piston and that way you get more oil in for lubing. Just my thoughts .
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Tue Feb 18, 2020 3:52 pm
Rod should be, an 1.500, wide. Side clearance has always varied, from crank, to crank, on Model T's.
At that, side play should should not be under .005, and not over .008. .010, and .012 is getting loose, although, many are, but it still doesn't make it right.
We always cut them to fit the crank, on the engines we built.
Just make sure the rods are in Aliment for, Twist, Bend, and off set. There is a large percentage they are not, or not done we built.
Herm.
Jig Poured Model T Rods, Jan, 2012 026.jpg (21.86 KiB) Viewed 6830 times
Jig Poured Model T Rods, Jan, 2012 010.jpg (26.21 KiB) Viewed 6830 times
Jig Poured Model T Rods, Jan, 2012 004.jpg (30.67 KiB) Viewed 6830 times
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Tue Feb 18, 2020 5:42 pm
The reason I asked is the ones in my 15 have up to 60 tho side to side play on almost new babbitt . MEL
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Tue Feb 18, 2020 9:22 pm
There is a std. size the crank is original but with crank grinding and spot grinding the radius they tend to grow, if your rods where std. width and your crank has been reground then you have some thing wider now, as Herm said as long as they are straight and not bent you are good to go.
RichardG
Last Name: Grzegorowicz
* REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Post by RichardG » Tue Feb 18, 2020 10:23 pm
ON THE MODEL T THE ROD IS BOLTED TIGHT TO THE WRIST PIN AND THE PIN IS SNUG IN THE PISTON BOSS,THEREFOR EXCESS SIDE DRIFT CAN BE CAUSED BY ANY OF THOSE POINTS THAT HAVE BECOME WORN, WE USED TO CALL IT PISTON SLAP, THE-- T-- ENGINE NOT BEING THE QUIET KIND, YOU CANT HEAR THIS, IF YOU HAVE THE IRON PISTONS THEY WILL SHRINK WHEN COLD, GIVING SIDE PLAY NOT MUCH MIND YOU AND UNTIL THE PISTON HEATS TO EXPAND TO SIZE, THIS MOVEMENT WILL TAKE PLACE, THE CRANK END OF THE ROD IS LETS SAY FIVE INCH FROM THE WRIST PIN, ANY SIDE MOVEMENT OF THE PISTON OR WORN PARTS WILL INCREASE THE DRIFT, THE BABBITT ON ETHER SIDE OF THE ROD WILL BECOME NARROW DUE TO THIS PRESSURE IN THE MOVEMENT RUBBING ON THE SIDES THE CRANK JURNIL, UP AND DOWN, IN OTHER WORDS THE ROD ON DOWN PRESSURE IS FORCED TO ONE SIDE AND ON THE UP MOVEMENT ITS FORCED IN THE OTHER DIRECTION. 60 THOW IS A BIT MUCH, THIS COULD BE CORRECTED SOME WHAT BY ADJUSTING THE RODS, IF YOU HAVE SHIMS, THE JOB WILL BE FAIRLY EASY, MY TEST IS A TINY BIT OF TOILET PAPER ,WHEN YOU FINNISH THE ADJUSTMENT PLACE THIS PAPER BETWEEN THE CAP AND CRANK, IF THIS LOCKS THE MOVEMENT, [DON;T PRY TOO HARD] YOUR OIL CLEARANCE IS FINE. HOPE THIS HELPS. GOOD LUCK.
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
Post by Kohnke Rebabbitting » Wed Feb 19, 2020 3:56 pm
Warning!!!! When using the Toilet Paper method," DO NOT REUSE THAT PRODUCT " for what it was originally intended, as now with the oil impregnation, it may have a tendency to leave an oil slick, or streak, and slide past the intended Target.
Herm.
Post by Scott_Conger » Wed Feb 19, 2020 4:00 pm
Herm
that is too funny :lol:
Last Name: Wrenn
Post by TWrenn » Thu Feb 20, 2020 12:33 pm
Pissing my pants laughing at that one Herm!
Sometimes we need a good shot of humor here!
:lol: :lol:
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Thu Feb 20, 2020 12:56 pm
Whoops! There it goes! :lol: :lol:
Mel King
First Name: Melvin
Last Name: King
Post by Mel King » Fri Feb 21, 2020 10:14 am
Thanks for all the advice . MEL.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Fri Feb 21, 2020 10:40 am
Only use "new" TP for this. You dont want that $h;# in the bearings.
First Name: Dallas
Last Name: Landers
