Anderson Timer question
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Sat Feb 22, 2020 8:26 am
Which part of the flat contact gets touched by the flapper first? The butt end or the ramp?
Anderson Timer
Anderson Timer
Ron Patterson
Re: Anderson Timer question
Post by Ron Patterson » Sat Feb 22, 2020 8:35 am
Ramp
The camshaft turns counterclockwise.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat Feb 22, 2020 9:17 am
The flapper contacts the end of the segment first and then rides down the ramp.
(The cam turns counter-clockwise if you are standing in front of the car. The cam turns clockwise if you are sitting in the car.)
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sat Feb 22, 2020 9:18 am
I agree. But that doesn't answer my question.
I am assuming that you are looking at the camshaft and flapper from the front of the engine to get the counter clockwise turn?
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sat Feb 22, 2020 9:26 am
Like this? Keep in mind that this view is reversed from what we normally see.
timer and flapper
timer and flapper
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat Feb 22, 2020 9:28 am
Yes, that is correct.
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sat Feb 22, 2020 9:36 am
All of my Model T life I have assumed that the flapper touches the ramp first, then "flaps" off the butt end to get ready for the next strike. That just seems more logical to me. Now, a project that I'm working on has me looking closely at the mechanics of the timer, and I thought "no way". After talking to several others their answer was - ramp first. So that is what brought up my question.
Thanks- Adam & Ron for your help.
aDave
First Name: David
Last Name: Dufault
Post by aDave » Sat Feb 22, 2020 9:53 am
Boy, thoser 1st two answers make this old mind really, terribly confused.....two different answers from extremely knowledgeable people...
Post by DanTreace » Sat Feb 22, 2020 9:59 am
Bill
Correct.
This is the 'normal' view of the Anderson flapper.
The flapper is a sliding, gliding contact rotor, unlike the roller type that have to spin at speed.
The flapper is a wipe contact, spring loaded.
IMG_7115 (500x375).jpg (89.06 KiB) Viewed 5329 times
248289 (2).jpg (87.56 KiB) Viewed 5329 times
Post by Norman Kling » Sat Feb 22, 2020 11:10 am
It makes good sense. The abrupt end of the ramp is timed so that the flapper hits each segment at the proper time for the spark.
Ron Patterson
Post by Ron Patterson » Sat Feb 22, 2020 12:14 pm
Adam
Your right and I am wrong.
Ron Patterson
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Sat Feb 22, 2020 1:29 pm
Ron- the camshaft does turn counter clockwise, as you stated, if viewed from the front.
cessna53195
Last Name: Skingley
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
Post by cessna53195 » Sat Feb 22, 2020 2:14 pm
You can fill the cup with axle grease, that will keep it lubed, and you won't need to check it for years...That is what I learned from those who service the T's at the Henry Ford. They service them once a year after about 5,000 miles, I am not sure what they do at that point , they could just put new ones in but I don't know for sure...I serviced mine 5 years ago and only drive about 200 miles a year, the grease does not drip out with heat...
