Old photo- Model T truck
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Thu Feb 20, 2020 8:16 am
Is it a 1916?
WayneJ
Last Name: Jorgensen
Re: Old photo- Model T truck
Post by WayneJ » Thu Feb 20, 2020 8:25 am
Interesting place to mount the tail lamp.
Wayne Jorgensen, Batavia, IL
1918 Runabout
Mike Royster
First Name: Michael
Last Name: Royster
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
Post by Mike Royster » Thu Feb 20, 2020 8:26 am
1916 I do believe.
Post by RajoRacer » Thu Feb 20, 2020 10:53 am
Looks like a "hearse hauler" !
Post by Rich Eagle » Thu Feb 20, 2020 2:02 pm
I would suggest it is a 1915 from the horn bulb mounted inside. The radiator even may have black paint on it. Wouldn't '16 have a horn button on the steering column? Also an early sign is the side lamp fount.
No chains are visible so it appears to be a shaft drive conversion. Demountable wheels look plenty Beefy.
It is quite different in many was to the T truck I have seen from that era.
Post by Mark Gregush » Fri Feb 21, 2020 10:02 pm
I have most of the sheet metal for a 20's roadster and have thought about doing something like that with the top, only shorter on my 21 huckster.
