Magneto light questions
Jim Sims
Topic author - Posts: 181
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
When was mag lights first used? When was the dimmer unit first used. When was the combination horn light switch first used ? Was the dimmer used with the push pull switch on the firewall?
Re: Magneto light questions
I can answer the first part of that. 1915 was the first year for electric lights. The only thing in the circuit besides the head lamps was the push-pull switch on the firewall. Somebody else will have to answer the rest.
The dimmer was used with the combo light/horn switch first 1918 model year, dimmer on dash. Later ignition /light switch on dash, the dimmer sat in place of the ammeter on magneto only T's up to 1927.
Older post with some factual info:
http://www.mtfca.com/discus/messages/11 ... 1292375409
