1927 Model T coupe trunk lid
JoeG48
First Name: Joe
Last Name: Gallagher
Post by JoeG48 » Sat Mar 14, 2020 5:59 pm
Does anyone know the steps needed to remove the trunk lid on a 1927 Model T Coupe.
Thanks for any and all help... Joe
joeg48@hotmail.com
Last Name: Humble
Board Member Since: 2006
Re: 1927 Model T coupe trunk lid
Post by Humblej » Sat Mar 14, 2020 7:03 pm
There is a hinge that bolts on to the top side edge of the deck lid on each end. You have to take one of them off, either side will do. The hinge is a plate with a protruding pin that fits into a hole in the body. Hinge bolts to the deck lid with 2 bolts. Might help to remove the bracket that holds the trunk open to allow you to lift the deck lid higher to find the hinges. Once you get one hinge off rotate the deck lid back to disengage the other hinge pin from the body.
JoeG48
First Name: Joe
Post by JoeG48 » Sat Mar 14, 2020 9:04 pm
Thanks Jeff ...I was able to get the Deck lid off ..... Thanks again ... Joe
