When were the brass magneto magnet spools used . ???
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Tue Feb 05, 2019 11:59 pm
While working on the speedster engine, I ran into a part I do not remember seeing before. I found some brass magneto magnet spools that were mixed in with the aluminum spools. I do not remember seeing any brass spools before, so I curious what years they were used. I found enough NOS aluminum spools to use as oil slingers on the speedster flywheel. Im not running a magneto in the engine, just the 16 spools. I believe I may have enough NOS brass spools to use instead of the aluminum spools. The brass spools weigh about twice as much as the aluminum spools. So I not really sure which way to go, The spools will go on the other side of the flywheel when I install the ring gear ...
Kerry
Last Name: van Ekeren
Re: When were the brass magneto magnet spools used . ???
Post by Kerry » Wed Feb 06, 2019 12:30 am
Parts books list them as part No 3257- magneto support- brass, up to late 1921 then the word brass is dropped.
Post by Steve Jelf » Wed Feb 06, 2019 12:55 am
Mid-teens for sure. I checked the encyclopedia and didn't find even as much as what Frank found in the parts books.
Post by Mark Gregush » Wed Feb 06, 2019 1:06 am
Donny you might want to read the post on bolt hardness. Re the grade 8 bolts.
https://www.modeltfordclubofamerica.com ... f=2&t=1075
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Wed Feb 06, 2019 10:04 am
Mark, I have read the posts on bolt hardness. I chose the grade 8 bolts because of the current post of "this is the way we do it" about how Herm rebuilds transmissions. He shows a flywheel with only spools installed for "oil slingers" when the mag is removed. In the photos the bolts appear to be grade 8. The post about bolt hardness also mentions that grade 8 is a good choice for a "static" load. but not so much for a "flexing" load.. I believe using the bolts as I will be using them is a "static" load. I see no "flexing" happening. With all that said a grade 5 should also be more than adequate. I already had the grade 8 bolts so that's what I planned on using......
The pictures are from the post about how Herm rebuilds transmissions.
Post by Original Smith » Wed Feb 06, 2019 12:03 pm
I think I've seen some real early ones that have no flange on top and bottom.
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Post by George Andreasen » Wed Feb 06, 2019 12:36 pm
My 1918 engine has a full set of brass (looks more like bronze) spools. I reused them during the rebuild.
