Period Picture- Hump"T"y Dump"T"y
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Sun Mar 08, 2020 9:05 am
Duey_C
First Name: Duane
Last Name: Cooley
Re: Period Picture- Hump"T"y Dump"T"y
Post by Duey_C » Sun Mar 08, 2020 7:50 pm
That's concrete! Cool side delivery box and solid front tires.
Look at that ol' boy lean into that heavy side load!
Cool pic.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Mar 10, 2020 3:48 pm
No money wasted on "unused" body work :-)
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Tue Mar 10, 2020 3:51 pm
And who needs tyres anyway? !
Post by Rich Eagle » Tue Mar 10, 2020 5:27 pm
This looks to be the same time and place.
Post by Scott_Conger » Tue Mar 10, 2020 5:54 pm
sure is, though I think it's a different load. Vehicle is a little farther away from the batten boards and characters in different positions, but you clearly have the nearly the same spot at a very slightly higher vantage point. Was the other photo part of the same collection you found?
Post by Wayne Sheldon » Tue Mar 10, 2020 6:45 pm
Silly me, I decided to figure which of the two pictures was taken first or second, and about how far apart. The sledge hammer standing almost identical, along with the shovel handle sticking up from the dug trench almost exactly the same, led me astray to thinking the two spots were right together. But I couldn't resolve the form stakes spacing. So I started looking at backgrounds.
Noting the power pole with the electrical transformer on it, and triangulating that against the house, it appears the first picture is first, while the second picture is about fifty feet farther down the road. Just goes to show how habitual people tend to be in placement of their tools. The sledge hammer and shovel are placed almost identically.
With such a light truck, "No money wasted on "unused" body work" as Adrian W said. A heavy load of wet cement could shift suddenly over to one side like that with interesting results?!
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Tue Mar 10, 2020 7:03 pm
Just a guess, but I'd say that the sledge hammer is a "marker" to tell the driver how far to spread one load of concrete. So yes, you could expect to see a sledge in that position in every action shot.
Post by Scott_Conger » Tue Mar 10, 2020 7:27 pm
Wayne
I think 50ft is an excellent estimation.
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Tue Mar 10, 2020 7:53 pm
Appears to be the same two trucks and drivers in each photo. Took a shot of each dumping.
Almost looks like the driver with the white shirt has shades on.
Cool photos. 8-)
Post by Wayne Sheldon » Tue Mar 10, 2020 9:28 pm
Thank you Scott C!
Dick F, Excellent point! Likely that both the hammer and shovel may have been used that way.
Wonderful photos! Thank you all.
Post by Rich Eagle » Tue Mar 10, 2020 9:51 pm
Taking a closer look I believe the truck has only moved 5 or 6 feet forward from the first photo to the second. I believe the circled rocks are the same and show this.
Both photos have been circulating the web for some time. Most recently I have seen them on Pinterest and Etsy. I seem to remember seeing them on some State's road construction article but can't remember which state. I can't make sense of the license plate to identify the state.
Lot of Fun!
Post by Rich Eagle » Tue Mar 10, 2020 10:52 pm
A little more research and a better copy of the photo has led me to believe it is a Maryland license plate. The figures at the right must signify a state or county road department. 1925 is the only dark plate with light lettering that has Marryland - Date at the bottom until '31 (red) or 33 (black).
Michael Paul
First Name: Michael
Last Name: Paul
* REQUIRED* Type and Year of Model Ts owned: 1911 touring, 1909 touring
Post by Michael Paul » Wed Mar 11, 2020 10:32 am
My guess is 1 yard of concrete in each dump, that's a lot of weight hanging out there! I yard weighs a little over 4000# it looks like a very dry mix, I wonder if there are any counter weights on the other side we don't see.
Have a great day, Mike
Jeff Hood
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Post by Jeff Hood » Wed Mar 11, 2020 11:50 am
I agree with Rich on the rocks. That dump box is only five or six feet long, and with the depth of the forms in the pictures, each load probably only makes five or six feet of progress.
Post by Rich Eagle » Wed Mar 11, 2020 12:54 pm
Here is a link to a Shorpy version of the photo I posted. The plate numbers suggest that the truck shown in the first picture in this thread has moved on. The next truck is unloading and a third truck is behind. {"Herr Dump Car Mfg. Co., 1925." A new sidewalk in Washington, or the capital's Maryland suburbs.} There are some nice comments with that article like "I was looking for a counterbalance when I noticed the rear wheels are farther apart than the front. Keeps it from tipping."
https://www.shorpy.com/node/4254?size=_original#caption
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Wed Mar 11, 2020 2:32 pm
Given the speed of those trucks and the fact that they don't amount to much more than a box on wheels with no ability to mix that concrete I'm thinking the batch plant had to be nearby. :D
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Wed Mar 11, 2020 3:47 pm
Looks to be a pretty "hot" load to crumble apart while dumping. I bet the had to beat it into the form.
