I have a 1927 Roadster with original floorboards and the draft deflector. It also has a Ruckstell with the shift lever in the middle. I found it difficult to install the top board with the draft deflector behind the pedals. I also have to bend the hand brake lever toward the middle to get that floorboard to fit over the Ruckstell shift lever and hand brake lever at the same time.
Do you have a method for installing the floorboards that makes it easy to get them in place? What order do you put yours in place?
Which end of the side hold down clips goes over the floorboards?
Thanks for any advice.
How to Install 27 Front Floorboards
Topic author - Posts: 206
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
- Last Name: Strange
- Board Member Since: 2013
Re: How to Install 27 Front Floorboards
I have my brake lever bent over to the left on my 1924 for more foot room. This made it impossible to get the rear floor board up past both the brake lever and my center Ruckstell shifter. I ended up cutting a notch out of the brake lever slot and re-attaching it with screws and a sheet metal plate so that I can remove that section and expose the notch when I want to pull up the floor board.
- Last Name: Codman
As I recall, I install the flat floorboard first, then the under-pedal board, and finally the over-pedal board. My '27 is a touring car, but both Snyder's and Lang's list the same floorboards for "open cars." I have had no real problems installing the board with the deflector, but there is only one position that will work. I kind of roll it around the top of the pedals. I can't help you with the clips - my floorboards are held down by gravity, the floormat, and human feet. I wouldn't bother with the clips even if I had them unless I was going to tow it on an open trailer at a speed above about 50mph. I have heard several stories about folks having to walk back to retrieve departed boards when they were towing on the highway. My solution for this was to purchase an enclosed trailer.
