Speedster Tool Box
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Speedster Tool Box
Post by Jeepbone1 » Tue Mar 31, 2020 8:12 pm
Finished up a three day project today. Finally after eight months of driving my speedster I got my butt in gear and got motivated to build the rear toolbox for my speedster. I may have gone a little overkill on this one but at least it has plenty of room and is solid as a rock. Final dimension ended up being 40”x15”x20” with a usable 38”x13”x15” inside space. The bottom was raised to accommodate the rear crossmember poking up through the deck. This thing is absolutely solid! And FYI it will easily hold 7 24 packs of your favorite beverages. Sure beats what little space I have just under the seat!
Jeepbone1
First Name: Brad
Last Name: Kirtner
Re: Speedster Tool Box
Post by Jeepbone1 » Tue Mar 31, 2020 8:13 pm
More pictures.
Jeepbone1
First Name: Brad
Last Name: Kirtner
Post by Jeepbone1 » Tue Mar 31, 2020 8:14 pm
Last of the pictures. Once the rain clears, I’ll get some better pictures in the daylight. May need one final sanding and additional coat of paint at a later date.
Last Name: Hjortnaes
Post by DHort » Tue Mar 31, 2020 10:44 pm
Looks great Brad. You will be able to go on long trips with that box. I do not think it looks too big. Just keep an eye on that hinge if it is not solid brass.
