How It's Made-Wood spoke wheels
Topic author - Posts: 1666
- First Name: Herb
- Last Name: Iffrig
- First Name: ROBERT
- Last Name: BERGSTADT
Re: How It's Made-Wood spoke wheels
I like it, thanks for posting, Bob
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
those wheels would not be on my car.they use the bolts to support the car seen at 2:14.you must bore the center of the wheel the same size as the hub.junk. charley
- First Name: Ed
- Last Name: Archer
- * REQUIRED* Type and Year of Model Ts owned: 1909 replica Transcontinental race car, 1915 2 man race car, 1918 American bodied speedster
- Board Member Since: 2009
Charlie's correct, The hub needs to really fit tight on the spokes. The person that uses those wheels will hear clicking sounds as he drives, after a few years.
Ed aka #4
Ed aka #4
I do not believe that enough information is given on the video to come to a conclusion one way or another. We don't know the hole size when the hub went in; don't know the clearance of the bolt holes; and do not know how much "squeeze" the rim places on the fellos and thus the hub.
Thanks for posting the video. Whether or not you agree with the technique, I found it interesting.
- Last Name: Shaver
you can clearly see the end of the spokes are square and the hub falls in, you should have to press it in,bolt holes look louse to me.charley
- First Name: Ronald
- Last Name: Dupree
Looking at the credits, this was filmed at Coker's wheel shop
Ron Dupree
Charlie
I agree, you should have to press it in. In a finished wheel. Those spokes have not been compressed at all yet. I am betting that once the rim is shrunk on, it would be very difficult to press the hub out... Just my guess. If it falls out after assembly, yeah, that'd be a problem. However, I am pretty sure these guys do not have wheels flying off of cars as a matter of course.
- Last Name: Shaver
scott, you can put a round peg in a square hole but it wont stay tight very long!!!!!!!!!!!!! charley
The pemise that wood wheel spokes are turned in a lathe is put to rest. That might work with later T spokes which are round, but not with oval or teardrop shaped spokes. I think a step was missed in the video. The hole in the centre looks undersized as the spokes are assembled in the wooden felloe. To be able to fit the hub, I think the hole was bored out to suit.
I could be wrong again.
- Last Name: Shaver
allan look again you can clearly see the spokes still square on the ends and the hub falls in.there was a wheel shop in calf that them that way we put them in a big lathe bored them out the made a spacer to fill the gap. charley
- First Name: Adam
- Last Name: Doleshal
I didn’t watch the video, but for what it’s worth; I have prints out of the Benson Ford for several wheels and the hub outside diameter to hole inside diameter is between a few thousandths slip fit to a few thousandths press fit. What was important was the precise relationship between the wedge and tennon end of each spoke.
- Last Name: Shaver
you can make all the spokes from one piece of wood but if the center hole is not tight the car is being carried buy the bolts!!!!!!!!!!!!!!!!!!!! charley
- Last Name: Codman
Whether you feel that the spokes were not done correctly or not, it was an interesting video. I watch How It's Made regularly, and have not seen that clip before. BTW: Recording that video and posting it online without written permission is almost certainly a copyright violation.
John
while well meaning, your concern is unwarranted for this particular video. It is posted by the company which produces these shows.
It is a valid point, though, in that many videos are reposts of other original work and is a useful cautionary statement. That does not appear to be the case here, though.
- First Name: Adam
That’s absolutely correct! That is why the bolt holes are between the spokes and every pair of spokes has a bolt between them. Also, the correct bolts have full size shanks and are a very good fit In the holes. All that, combined with the fact the spokes are clamped between two steel plates would make a wheel that is nice and tight EVEN IF the hub was a bit of a slip fit. Such a wheel would perform adequately until such point it was “old and worn out”. Would a wheel with a “light press fit” hub last longer than a wheel with a “slip fit” hub? The answer might range from maybe to probably. Yes, I would prefer a light press fit in my wheel, but the Ford prints tell a story that a slip fit was also acceptable to them so it’s possible a slip fit could have good longevity too.
- Last Name: Shaver
tha fit on the wheel in the film looks to be about 1/8 th. as i rember the wheels that came from calf after we boared them we had to make 3/8 s ring to press on the hub charley
My favorite wheel shop is Calimers in Pennsylvania. Their work is amazing. I wouldn't go anywhere else, plus they are accommodating. Their wait list is usually about six months. Some time ago I needed a late 30 X 31/2 steel felloe wheel respoked, and they worked my wheel in with another customers!
That is what I call service.
- Last Name: Codman
Scott - Glad to hear that. If the video was posted by the owner of the work, there's no problem. Thanks for the clarification.
