Starter Oil Seal Part number
Topic author - Posts: 485
- First Name: Jack
- Last Name: Putnam
What is the part number for the modern seal that goes into the starter busing when rebuilding the Model T starter.?
- First Name: Andy
- Last Name: Loso
Re: Starter Oil Seal Part number
should be a 6595 cr
- First Name: Adam
- Last Name: Doleshal
It has to be the CR seal. If your seal supplier crosses the number to a different brand, it likely won’t work.
- First Name: Kevin
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- Board Member Since: 2004
Chicago Rawhide 6720 Use nothing else.
