Can anyone help with some drive shaft bushing measurements?
Darren J Wallace
First Name: Darren
Last Name: Wallace
* REQUIRED* Type and Year of Model Ts owned: 1913 Canadian Touring 1905 Queen model B
Post by Darren J Wallace » Fri Apr 10, 2020 12:46 pm
Hello all,
I''ve roughed out a bronze bushing for my two piece drive shaft on my lathe. I need some measurements to finish it but cannot find them on the internet. What is the pre-finished thickness of the flange? Also, should the outside diameter of the flange be just a few thou slide fit into the I.D. of the ball casting? Or should it be a loose fit? From the pictures I did find on the net for "regular" off the shelf bushings, that O.D "appears" to look to be around 1.5". The actual I.D. of my ball casting is 1.563". I would think it should be a nice slide fit. I want to leave some meat on it to face it off for proper fit with the U-joint. Thankfully, I have a lathe and steady rest big enough that I can finish it with the lathe.
Thanks in advance!
Dropacent
Last Name: Morsher
Re: Can anyone help with some drive shaft bushing measurements?
Post by Dropacent » Fri Apr 10, 2020 4:42 pm
I found a problem with the reproductions , but used it to my advantage. I’ve done two in the past couple of years. The bushing was supposed to be a light press fit, but both just dropped in. This made it easier to take in and out to face until I got the perfect fit, then I installed it with bearing lock glue. This didn’t really answer your question , and I don’t have a loose one to measure.
Dropacent
Last Name: Morsher
Post by Dropacent » Fri Apr 10, 2020 4:46 pm
Darren, I have a NOS Babbitt one here and the flange is .180 thick. It doesn’t appear swollen but could be. This should get you in the ballpark.
Post by DanTreace » Fri Apr 10, 2020 5:36 pm
New repro measured o.d. 1.313" Flange thickness .170"
Grease groove on flange and down one side (where you drill your hole for the dope cup) .180" wide
Old worn Babbitt measured o.d. 1.312". Flange .180" and grease groove .155" wide
Yet to have any trouble with repro's, they need a bushing driver to place, you don't want the bushing to rotate or move forward.
Darren J Wallace
First Name: Darren
Last Name: Wallace
Post by Darren J Wallace » Fri Apr 10, 2020 6:34 pm
Many thanks Tim and Dan!! What is the actual flange O.D. ? Is it 1.500" or is it bigger? My bushing will be a be a press fit for sure.
Scott Kramer
Last Name: Kramer
* REQUIRED* Type and Year of Model Ts owned: 1909 touring,1913 touring,1921 Coupe,1923 lawnroller
Post by Scott Kramer » Fri Apr 10, 2020 6:45 pm
Hi Darren,
I have a new one, that I bought for my 1913 T. If you need to see it let me know.
Scott
Post by DanTreace » Fri Apr 10, 2020 8:19 pm
Outer flange o.d is 1.5625"
The bushing shaft o.d. is what is pressed to secure.
Darren J Wallace
First Name: Darren
Last Name: Wallace
Post by Darren J Wallace » Fri Apr 10, 2020 8:29 pm
Many thanks Dan and Scott!!
Dropacent
Last Name: Morsher
TMI .....Can anyone help with some drive shaft bushing measurements?
Post by Dropacent » Fri Apr 10, 2020 9:12 pm
Ok, probably TMI but here goes. How many have plucked these babies out of a driveshaft and just threw them in the scrap? I looked at my cosmolined NOS one today, and had to degrease it. This is ford script. A steel shell, with a babbit rim and lining. What I found interesting is the single grease groove stopped short from the end. Also, the spot for the grease hole is in the steel shell, which would make it easy for the mechanic to install correctly, right side up. Grease groove and grease hole up. An easy drill for the mechanic through the babbit for the grease hole. Best of all, this original style would limit oil travel8mg back to the rear axle. Ok , TMI but I thought pretty neat.
Darren J Wallace
First Name: Darren
Last Name: Wallace
Post by Darren J Wallace » Fri Apr 10, 2020 10:16 pm
Very interesting Tim! Thanks for sharing!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Fri Apr 10, 2020 10:21 pm
You have some cool stuff Tim ! Thank you.
