Canadian Ruckstell tags
Les Schubert
Topic author - Posts: 1364
- First Name: Les
- Last Name: Schubert
I m thinking about doing a run of these?
NO I don’t have a cost yet!!
If you have any interest let me know
John Page
- Last Name: Page
- Board Member Since: 2010
Re: Canadian Ruckstell tags
Hello Les,
I am no expert on the Canadian Ruckstell tags. I think the oval tags were attached to the later axles.
Pictured below is the original one that is on my 1924 Ruckstell axle.
Note M.F.D. by Canadian Acme Screw & Gear Company Ltd.
Best regards, John Page, Australia.
Kerry
- Last Name: van Ekeren
I have 2 big drum Ruckstells, one of each tags.
Les Schubert
- First Name: Les
I will make a couple of the oval ones for my own use anyway.
The method does not particularly scale up for volume production.
The process;
1. Make a digital drawing
2. Print on a plastic sheet in a laser printer
3. Transfer the ink to a piece of brass sheet
4. Etch the metal
5. Cut out and polish
The process;
4. Etch the metal
Dennis K Anderson
- First Name: Dennis K
- Last Name: Anderson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Mail truck
I will take one
I have seen both styles here in California.
Brian B. Kansas City
- First Name: Brian
- Last Name: Beatty
- * REQUIRED* Type and Year of Model Ts owned: 20's Speedster
Les,
I could really use one. The tag on my Ruckstell is the same as the picture you posted but is in poor shape.
Brian
Brian
