Exhaust Manifold Running Red
Rich Huggins
Topic author - Posts: 107
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Hi my exhaust manifold runs bright red while driving, i smelled something burning ! oh no my floor board is on fire. Luckily i had water, burnt half way through the 3 piece floor board covered it with a sheet metal heat shield. I did drive home with no floor boards ,dam that was hot on the feet is this normal
Re: Exhaust Manifold Running Red
Missed timed/not enough advance or too retarded or running way to lean. How far do you run the spray needle when driving? Running way too lean is will do this too. Unburnt fuel helps cool valves and exhaust manifold as it pass out the engine.
