What do you use to take off old varnish / laquer....
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Post by TBones12 » Sun May 03, 2020 12:48 pm
What do you use to take off old varnish. or lacquer or whatever coating they put on brass lamps after they polish them.
I accidentally tried polishing older brass with a wire wheel brush and took off the shinny coating. Now I have to do the whole thing.
Thank you in advanced. Bob
AndreFordT
First Name: Andre
Last Name: Valkenaers
Re: What do you use to take off old varnish / laquer....
Post by AndreFordT » Sun May 03, 2020 1:14 pm
Try with Cellulose Thinner. It works for me. Soak it in a bucket over night.
After I used SIDOL to clean the brass and polished it with journal paper.
Good luck
Andre
Belgium
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sun May 03, 2020 1:36 pm
Acetone! But you have to be careful with it, especially when disposing of used rags.
Last Name: Patrick
Post by jiminbartow » Sun May 03, 2020 1:38 pm
Lacquer thinner will take off lacquer and old varnish as well. I’m curious. Why were you using a wire brush on brass? When polishing a soft metal such as brass, I have always used a bench grinder equipped with a buffing wheel coated with jewelers rouge to attain a mirror finish. A wire wheel will do nothing but deeply scratch and permanently damage the surface of the brass. I guess it is ok if you are seeking a dull scratched surface. Jim Patrick
Post by Scott_Conger » Sun May 03, 2020 1:40 pm
a wire wheel will do irrepairable damage to smooth polished brass. A lot more brass will have to be removed to get a pit-free surface again and you will lose a lot of detail. Many logos and other delicate details are destroyed this way. Change tactics.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sun May 03, 2020 4:43 pm
I had lamps that were treated with something other than lacquer and it was tough stuff. Nothing but soaking in acetone for several days would remove it.
TBones12
Last Name: Poane
Post by TBones12 » Sun May 03, 2020 8:26 pm
Thanks for the advice. I mentioned the brass wheel because I sometime use it on badly tarnished metal including certain thick brass parts such as carburetor knobs, and that's only if my regular polish does not remove it. Yea, I learned my lesson, I've ruined brass before by using a wheel!
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Mon May 04, 2020 12:22 am
I think MEK will attack just about anything it is nasty stuff.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Mon May 04, 2020 4:59 am
I bought some lacquer thinner a few years ago to dissolve some dried boiled linseed oil. It was the "low odor" variety, which was all I could find at the time, it was also the "low performance" variety. It didn't do squat, the old good lacquer thinner would have melted it out in a heartbeat. Gosh, I'm so glad the EPA is protecting us so well. :x :x :x :x Dave
1925 mostly original coupe.
Robert Bente
Last Name: Bente
* REQUIRED* Type and Year of Model Ts owned: 1916 runabout, 1921 touring, 1915 touring
Post by Robert Bente » Mon May 04, 2020 9:39 am
I soaked these in hot water over a period of several days. Then used a piece of wood and a finger nail to peal off lacquer coating.
It took awhile but the results was worth the effort.
