New old Coupe joins the garage
Topic author - Posts: 4084
Just brought home a ‘25 Coupe , we had been thinking of a closed car for cold or rainy tours. Been off the roads for years, but won’t take much for making ‘Doc’ roadworthy.
ModelT46
- First Name: Darel
- Last Name: Leipold
Re: New old Coupe joins the garage
A very nice example of a good year.
Thanks Darel
It's an older restoration, wood framing is solid, the engine build date June 3, 1925. Has the metal doors and they close so nice.
Paint has some age cracking, but this will be a tour car. First closed car I've had.
Will get it running to check out stuff, and then go through the rest to make the chassis ready for the road.
Duey_C
- First Name: Duane
- Last Name: Cooley
Nice Coupe!
Hehe, Doc ready...
Hehe, Doc ready...
- Last Name: Hjortnaes
Hey Dan,
You need to go online and buy one of those fake MD diplomas. Put it in the car so you can
call it a Drs Coupe.
Kerry
- Last Name: van Ekeren
Bought one the same to flip but "she who must be obeyed has fallen in love with it and now her favourite
MWalker
- First Name: Mike
- Last Name: Walker
Looks pretty slick, Dan.
Dan B
- Last Name: Blaydon
Looks very nice. Would love to drive a closed car T someday. Will be interested in what you find as you refresh.
Congrats!
Congrats!
Nice looking car and appears to be very solid! I have a 24 Coupe I restored that belonged to my Grandfather. One thing though! Its great fun replacing the transmission bands in a Coupe, nice and tight and a great way to learn how to be a contortionist.
Well, first thing the morning, checked oil, good, and clean too.
Put the 2013 battery on charger, had lots of fluid in it, used the battery electrolyte tester, read in the high fair, then charged up 100% fine.
Put on known good carb, and gas tank was dry but very clean, put in some gas, drained the sediment bulb, let the gas run clean thru the gas line before plumbing to the carb.
Drained the radiator, very little debris ran out, flushed and refilled with anti-freeze and distilled water solution.
Aired up the tires to 60psi all around.
Turned on the gas, climbed in, pressed the starter button.....nothing.
Key on, no coil buzz.
Headlamp switch on, just dark
Pressed the horn button, and BEEEEP....??
Here's the wiring at the terminal block, note where big fat hot Yellow wire is placed...Oops, time for wire trace and check.
Well, didn't take long to suspect that older 6v storage battery, thought it got charged too quick. So pulled it and sure enough the re-test showed poor condition. Could barely spark the coils, when it did, pressing on the starter button quieted the coil buzz.
So removed and installed a good trouble free Optima 6v, maybe a few years old, but strong enough to turn over the engine multiple times as I set the carb adj. After that, starts fine and runs pretty good for a very old restoration.
So with Doc warmed up, took him around the 'hood. Back home walked around with engine running.
Here's today's video:
https://youtu.be/gC5dI68OYRU
That car looks good. If it runs as good as it looks, you got a good car. However, you might get some rain, but cold weather? I thought Florida was the "sunshine" state. Here in southern California I have driven my open cars, and I don't even have side curtains. In the mountains in winter we sometimes have rain or light snow, but have driven them without a problem. Just dress in layers. Anyway, be sure all the fittings on your exhaust system are tight and keep the windows partly open. You can't smell carbon monoxide but it can make you sick. The first symptom is a headache. Next is death! With the type floorboards in a T or in an A also, you should leave some ventilation when driving.
Norm is right about ventilation. I drive with my windows cracked a bit. Those old advertisements about riding in comfort in a closed T are about about half right. They don’t mention about the hot engine and the things that go along with it.
But a T is a T and that’s what it is!
KLTagert
- First Name: Kathy
- Last Name: Tagert
- * REQUIRED* Type and Year of Model Ts owned: 1917 Runabout, 1918 Coupelet, ‘21 Centerdoor, ‘22 coupes, ‘23 Roadster and touring, ‘25 roadster pickup, Fordor, and coupe, ‘26 Coupe
You'll have a good time in your new coupe. We love our '25 Coupe for cool/cold weather touring. Rebuilt engine and tranny - she hauls butt. Was mistaken for having a ruckstell in it hauling up the hills.
