5 hole brake drums
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
5 hole brake drums
Post by Dennis_Brown » Mon May 11, 2020 10:41 pm
How hard are good used 5 hole large brake drums to come by or trade for?
Can 6 hole drums be redrilled to fit?
Re: 5 hole brake drums
Post by TRDxB2 » Mon May 11, 2020 11:21 pm
There have been several offered & sold on MTFCA recently. Some are still on ebay condition :?
Try Iola Kansas Model T Haven https://vintagecarsandparts.com/
https://www.ebay.com/itm/Model-T-Ford-1 ... 1265!US!-1
Or use this to search for more
https://www.ebay.com/sch/i.html?_from=R ... brake+drum
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Tue May 12, 2020 12:35 am
You would not be the first to drill brake drums for the opposite pattern. Be aware that the original wire wheel brake drums had a raised tab alongside the stud holes to lock the studs from rotating. You will probably be using splined, press in studs so the tab would not be necessary or you could simply put a small weld on the stud to lock it in. You will also have one hole that overlaps one of the previous holes. This will be problematic if you intend to “drill” the new holes, but the old hole could be welded up prior to drilling the new hole to make life easier
Last Name: Hatch
Post by Dan Hatch » Tue May 12, 2020 5:59 am
Email me I may have some. Dan
Last Name: Hatch
Post by Dan Hatch » Tue May 12, 2020 11:03 am
Got one email me if you want it. Dan
