I have a steering wheel spider that has a riveted hub and certainly look like a Model T spider. I would be for a pretty small steering wheel.
Different than other spiders I have this one doesn't seem to have a tapered shaft. The shaft hole is same size on either side. Did some model Ts have strait shafts for the steering wheels?
Thanks in advance for your response.
Steering wheel spider
Topic author - Posts: 42
- First Name: Bobby
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
- First Name: Jim
- Last Name: Sims
Re: Steering wheel spider
Model T's all have the non tapered shafts. You have the common T spider.
- First Name: Bobby
- Last Name: Wright
Jim---
Thanks for your response. It inspired me to get up and go to the shop and see what was going on. And you are correct They are straight and the reason this one didn't fit was it just needed a serious cleaning to get it on. And I learned my assumption Model T steering wheels would only do on in one direction was incorrect. Love it when I learn something Thanks.
- Last Name: Menzies
- Board Member Since: 2012
I was in Reno one year and went to the museum where they had the Model T prop from Flubber and I noticed they had the steering wheel on upside down I mentioned it to the curator and he was adamant it was on correctly and I equally assured him it was not, he responded that it can't go on upside down, I said the proof is right there that it can. He dug out the advertising poster in total frustration only to find it was on upside down. He changed it right there in front of me.
