In the thread on the self-destructing magneto, R. V. Anderson commented that a weak mag could indicate cracked magnets. How weak is weak ? What’s the best test for magneto strength ? Do you need instruments ?
My Lizzie starts readily on battery when cold, but I haven’t had a similar response cranking on mag and haven’t worked at it, it’s just too easy on bat ! On the other hand, once warmed up, a quarter turn on mag, and she fires right off. Comments, please ?
Weak mag ?!?
Rich Bingham
Topic author - Posts: 1942
- First Name: Rich
- Last Name: Bingham
Weak mag ?!?
"Get a horse !"
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Weak mag ?!?
An AC voltmeter is useful.
Re: Weak mag ?!?
Analog at that - have heard digital doesn't like the output ?
Ron Patterson
Re: Weak mag ?!?
FunProjects St. Louis magneto tester is the best way to measure the output of a Model T magneto.
- Attachments
- St Louis Magneto Tester.docx
- (13.06 KiB) Downloaded 148 times
