Where does this go???
Marty Bufalini
Topic author - Posts: 193
- First Name: Marty
- Last Name: Bufalini
Where does this mount? On the front seat kick panel?
Thanks in advance.
Thanks in advance.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
Re: Where does this go???
It mounts along the passenger front door pillar for the 26-27 fire wall mounted fuel tank.
- Last Name: House
I’ve never seen one but judging by the ad “ for late model Fords with the gas tank under the hood” leads me to believe it connects to the ‘New and Improved’ sediment bulb. If so, I’d think this accessory would be fairly unnecessary because it’s easy to lift the gas filler lid, unscrew the gas cap and get the wood gauge out to check gas level. Now the earlier Model T s with gas tanks under the seat requires your lady to get out and you wrestle the seat springs to check the gas. That gas sight gauge accessory of the era that’s still being reproduced today makes a lot more sense.
People wanted convenience just as much back then as now! You could sit in your seat and see that you were getting the gas you payed for.
- Last Name: House
So, “if you could sit in your seat” in a Ford with the gas tank under the hood......Where Does This Go ??! Mark??
Gary Gregory
- First Name: Gary
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster
I had one on my 27 Roadster. It was attached on the passenger side pillar where the kick panel attaches. And yes you can see it from the seat.
Might be similar to this too.
http://www.mtfca.com/discus/messages/33 ... 1383352861
Marty Bufalini
- First Name: Marty
So, this wouldn't work on my 1914?
- First Name: Jeff
- Last Name: Humble
No Marty, its for a 26-27 improved Ford.
jsaylor
- Last Name: Saylor
Similar to this one in my 27 Tudor.
- Last Name: House
OK, I’m a visual kinda guy and now I see where that accessory gas gauge is planted. But how is it integrated into that ‘upside down question mark’ New and Improved gas line ? I wrongly assumed it fastened to the sediment bulb.
