Survey
ModelTWoods
Topic author - Posts: 1555
- First Name: Terry
- Last Name: Woods
Survey
Just would like to see the results. I know some of you say "just use all steel plates in the transmission the way the factory built them'. There are others who want a more positive neutral without having to be a master T mechanic and fine tune a transmission, so, for those not using all steel plates, what is your preference: Turbo 400 style discs, or Watts/Jack Rabbit type discs?
Bands? Cotton (Scandinavia), or Kevlar? (not considering wood or anything else)
- First Name: Keith
- Last Name: Townsend
Re: Survey
Watts clutch
Kevlar
Kevlar
- First Name: Adrian
- Last Name: Whiteman
Re: Survey
Steel
Kevlar
(positive neutral too)
Kevlar
Ron F
- First Name: Ronald
- Last Name: Fishback
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1926 Touring, 1926 Pickup
Re: Survey
turbo 400 in 1916 Touring, 1926 Touring and 1926 Pickup.
Ron F
Ron F
- Last Name: Strange
- Board Member Since: 2013
Re: Survey
My Betsy came to me with a Jack Rabbit clutch. I have no complaints about it. It is "grabby" compared to the stock all-steel clutch, so I have to ease it into high instead of letting the pedal "snap" up.
I have a Watts clutch on the shelf if the Jack Rabbit ever gives out. Sorry, it isn't for sale.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Survey
Just a little food for thought here...
Survey results can be biased. They are the opinions of people who answer surveys...
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: Survey
Opinions are obvious, and if a
person likes what he has, they can be biased, but that kind of information is what I wanted to hear and read. I have my opinions and biases, too. I just wanted to see how many owners thought along my lines.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Re: Survey
400 clutch/ Kev.bands.
- Last Name: van Ekeren
Re: Survey
I rebuild several T's a year. always fit and recommend modern clutch packs to the owners. I push T's in and out of the shop every day to get working room, something that is not easy with the original clutch when one is a senior
Adam
- First Name: Adam
Re: Survey
That’s what I tell telephone surveys...
The answer here is:
-Kevlar bands
-New ductile iron low drum
-Original Ford reverse and brake drums are okay if in good condition.
-Original Stock Ford clutches that have been properly cleaned, inspected, and qualified.
-Original clutch spring that tests 95#’s or better at 2” compression.
The answer here is:
-Kevlar bands
ModelT46
- First Name: Darel
- Last Name: Leipold
Re: Survey
Steel works great.
Darel
Darel
ModelT46
- First Name: Darel
Re: Survey
I use always a NOS sprig.
