12 Volt Geared Starter
Last Name: Juhl
Post by Oldav8tor » Sat Jun 27, 2020 7:14 pm
Does anyone have experience pro or con with the new production 12 volt geared starter that some vendors carry?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: 12 Volt Geared Starter
Post by BE_ZERO_BE » Sat Jun 27, 2020 7:36 pm
It's interesting to say the least.
Looks as though the "Bendix Gear" is engaged in the flywheel all f the time.
That raises a concern about longevity.
Respectfully Submitted,
Be_Zero_Be
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sat Jun 27, 2020 8:06 pm
The Bendix gear is actuated by a solenoid, as per a modern starter. The pic shows it at rest with the Bendix retracted.
Post by Jerry VanOoteghem » Sat Jun 27, 2020 8:35 pm
So, if this is retracted, that must mean that the gear engages when extended from the position shown? If that's the case, then the bendix gear engages on the front facing side of the ring gear, versus the rear facing side, as with a stock T starter. That being the case, is it necessary to flip your ring gear over so that the lead cuts in the ring gear teeth are now facing the incoming bendix gear?
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Post by Rod » Sat Jun 27, 2020 9:19 pm
I have two of these starters and they work great. No you do not need to reverse your ring gear. The gear on the starter has the correct angle to engage the ring gear. I highly recommend this WASP starter.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Sat Jun 27, 2020 9:20 pm
I have one on my A and it works the same . I took a leap and installed without flipping the ring. Been working great for the last 2 years. It’s a great little starter.
Jeepbone1
First Name: Brad
Last Name: Kirtner
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
Post by Jeepbone1 » Sat Jun 27, 2020 11:56 pm
I saw a guy use one on a speedster tour last year. They’re quick and very quiet. Cool little units. He seemed very pleased with it.
Brad
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sun Jun 28, 2020 12:03 am
Reams Auto Electric shop in the Dallas, TX area will rebuild and rewire your stock 6 volt to 12 volts for $395.00, and they'll include a rebuilt bendix and bendix cover They have one on EBAY 324203613968, as I write.
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Sun Jun 28, 2020 5:55 am
If you have a hot soldering iron or mini-torch you can modify your existing starter for 12 volt operation pretty easily.
John Illinois
Last Name: Burgett
Post by John Illinois » Sun Jun 28, 2020 8:53 am
My model A ring gear was starting to move forward. I did not feel like taking the engine out to fix it so I tapped the ring gear back and installed a gear drive starter. Since it engages from the front the ring gear can not move.
I have used it for a couple of years and it works great but it sure does not look like an antique starter.
John
