1914 Cowl lamp issue. How to fix this?
critterpainter
First Name: Bill
Last Name: Dodd
* REQUIRED* Type and Year of Model Ts owned: 14 T Touring
Post by critterpainter » Sat Jun 27, 2020 11:32 pm
I was putting the shiny stuff back on my early 14 and came across this
All 4 pins on both cowl lamps are the same.
They are FORD victor Model 2 lamps
Now what??
14 Touring
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: 1914 Cowl lamp issue. How to fix this?
Post by D Stroud » Sun Jun 28, 2020 2:55 am
I'd be willing to bet Rich Eagle could figure out something. ;) Sorry Rich, I don't mean to add anything more to your project thoughts. :D Dave
1925 mostly original coupe.
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Sun Jun 28, 2020 9:07 am
Cut it off, drill it out get a piece of brazing rod and solder it in place. I went a bit longer on mine and filed it to fit. Wasn’t very difficult but in took two tries before I was happy.
Post by Rich Eagle » Sun Jun 28, 2020 11:29 am
Thanks David. I think Mark has a good fix. I've never had to but sounds like it would work fine. A soldering iron would be better than an open flame if there are kerosene fumes inside.
critterpainter
First Name: Bill
Last Name: Dodd
Post by critterpainter » Sun Jun 28, 2020 11:57 am
Thanks, I didnt think of brazing rod. Now to give myself a refresher course on planning carefully.
14 Touring
