Checked the rod bearings and shims because I noticed an increase in engine noise during coasting. Good thing I did. All rod bearings loose back/forth play with all shims removed and excessive Left/Right play (crank out of round?) Rod cap for number 2 was missing a chunk of Babbit. That's a show stopper.
Now the dominoes begin falling.... Crank is out of round, re-babbit bearings, check/lap valves/lifters, check/replace rings, check cam and gears, 4th main leaking/replace, check trans; clutch plates, magnets/keepers, etc, etc, etc..... Out of my league here; I'll stick to the electrical system. Time to seek professional help. Interested in recommendations for a good engine re-builder in the NJ area. Thanks!
Engine Re-builder Recommendations in the New Jersey Area
MKossor
Topic author - Posts: 547
- First Name: Mike
- Last Name: Kossor
Moxie26
- Last Name: Jablonski
Re: Engine Re-builder Recommendations in the New Jersey Area
Mike; almost 20 years ago we had the engine in our 26 run about redone at Schwalms Babbited Bearings in Strasburg, PA . Proprietor Ora Landis runs a strict and clean shop The shop started years ago specializing in Model A rebuilds, but wisely expanded to other makes and Model T Fords. We had them do a short block rebuild and also straightened the engine pan, and Fred Houston rebuilt the transmission. Ora put everything together and the engine has been running great . There are others in the area that I do trust Ora Landis.
Ralph F
- First Name: Ralph
- Last Name: Fitz-Gerald
Pats Restoration in Conn.
