13T - KW Coil Box Switch
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Fri Jul 03, 2020 7:24 pm
I’m rebuilding the coil box and had a question about the ignition switch. This KW switch I haven’t been able to find a lot on... was this an accessory item?
Thank you,
Darin
Re: 13T - KW Coil Box Switch
Post by RajoRacer » Fri Jul 03, 2020 8:15 pm
Yes, it was an early "anti-theft" device - I have/had a NOS one that is now on our '14 Touring. I'll attempt to find a photo.
Last Name: Wrenn
Post by TWrenn » Fri Jul 03, 2020 9:40 pm
Is that far right contact "spring" kinda small compared to the others? Or is it just an optical illusion in the picture?
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Fri Jul 03, 2020 9:48 pm
Not an optical illusion... part of the reason I’m rebuilding the coil box. Broken prong on the bottom copper, too.
Darin
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Fri Jul 03, 2020 10:10 pm
Steve,
A picture would be great. I’ve found one pic online which appears to show the letters are white... I want to ensure that’s right because I plan on having the wife paint the letters if that’s the way it is supposed to be.
Darin
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Fri Jul 03, 2020 10:23 pm
The only pic I’ve found so far.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri Jul 03, 2020 10:45 pm
This is the coil box and switch on my ‘13. The knob in the right of the switch body is the “key”. It’s a brass shaft that makes it “impossible” to throw the switch when it’s removed. I think the switch plate is supposed to be black, with the inscription in relief unpainted.
Good a time as any to review when the metal coil boxes appeared. (?). I love those locking devices for the coil box switch. Wonder how many different makes there were ?
"Get a horse !"
Post by Original Smith » Sat Jul 04, 2020 10:43 am
The switch plate you have pictured only had the circle with KW in it painted black.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Sat Jul 04, 2020 11:37 am
Thanks for that, Larry ! I’ll touch it up next winter. :D
"Get a horse !"
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Sat Jul 04, 2020 4:15 pm
Here is a little earlier K-W "AUTOLOCK" with a brass cover I have on my car.
K-W also made a Master Vibrator with the same switch but the cover is stamped "MASTER VIBRATOR".
The base of both of these look like a regular '13/'14 Model T metal coil box switch but the inside is different.
Patent date is January 23, 1912, same as Darin's.
