Original 1913 KW Coil Box
Post by Original Smith » Sat Jul 04, 2020 2:38 pm
There is a discussion on an aftermarket KW Switch today. Here are some photos of an authentic original KW Box that I've had for years, and started restoring it a month ago, with Randall Andersons guidance. I've rebuilt a half dozen of them over the years, but have never refinished one. I used Minwax Helmsman spar varnish, and put 5 coats on it, sanding each coat as I progressed. Enjoy the photos!
Re: Original 1913 KW Coil Box
Post by Original Smith » Sat Jul 04, 2020 2:41 pm
I guess I can only post so many photos at a time, so here is two more.
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Sat Jul 04, 2020 3:52 pm
Beautiful work, sir! Thank you for sharing... it’s basically a work of art 100+ years down the road.
Darin
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Sat Jul 04, 2020 3:56 pm
It would be fun and inexpensive to have reproductions of that label of instruction pasted inside the box lid. Is there any interest ?
"Get a horse !"
R.V.Anderson
First Name: R.V.
Last Name: Anderson
Post by R.V.Anderson » Sat Jul 04, 2020 9:05 pm
Matter of fact, yes; I've been working on it awhile. Will reproduce them when it is as close to perfect as I can get it.
James_Lyons-WV
Last Name: Lyons
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
Post by James_Lyons-WV » Sat Jul 18, 2020 5:01 pm
Larry... Great work!
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Sun Jul 19, 2020 11:59 am
Larry, your switch looks great as does the rest of the box.
Great job!
