T rad baffle
Topic author - Posts: 670
- First Name: Bruce
- Last Name: Compton
- * REQUIRED* Type and Year of Model Ts owned: 1921 Coupe, 1925 Coupe
T rad baffle
The brass baffle in my "26 T rad had come loose and was rattling around in the tank. With the rad removed and with some difficulty I was able the cut into smaller pieces and remove the pieces through the top hose hole. Solder and I don't get along too well so removing parts of the top tank was not going to happen. My question is; can I run this otherwise perfect rad without the baffle? Thanks : Bruce
- First Name: Dennis
- Last Name: Seth
Re: T rad baffle
I believe the baffle is installed in the radiator to help the water circulate across all the tubes. It may not cool properly without it.
Re: T rad baffle
Interesting past discussion on a loose baffle http://www.mtfca.com/discus/messages/50 ... 1447820350
