Original 1913 KW Coil Box
Topic author - Posts: 3971
There is a discussion on an aftermarket KW Switch today. Here are some photos of an authentic original KW Box that I've had for years, and started restoring it a month ago, with Randall Andersons guidance. I've rebuilt a half dozen of them over the years, but have never refinished one. I used Minwax Helmsman spar varnish, and put 5 coats on it, sanding each coat as I progressed. Enjoy the photos!
Re: Original 1913 KW Coil Box
I guess I can only post so many photos at a time, so here is two more.
Darin Hull
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
- Board Member Since: 2010
Beautiful work, sir! Thank you for sharing... it’s basically a work of art 100+ years down the road.
Darin
Darin
Rich Bingham
- First Name: Rich
- Last Name: Bingham
It would be fun and inexpensive to have reproductions of that label of instruction pasted inside the box lid. Is there any interest ?
"Get a horse !"
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Matter of fact, yes; I've been working on it awhile. Will reproduce them when it is as close to perfect as I can get it.
James_Lyons-WV
- Last Name: Lyons
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
Larry... Great work!
Brent Mize
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Larry, your switch looks great as does the rest of the box.
Great job!
Great job!
