Model T versus Model A Valve Springs
ModelTWoods
Topic author - Posts: 1584
- First Name: Terry
- Last Name: Woods
What is the difference in diameter, length, and spring pressure of Model T, Model A, and flathead V8 valve springs? If a owner wanted slightly more spring pressure to run with a high lift cam, could A or V8 springs be used if they provided higher spring pressure and were compatible in size? Would using stock reproduction springs with shims be better?
Erik Barrett
- First Name: Erik
- Last Name: Barrett
- * REQUIRED* Type and Year of Model Ts owned: 1913 speedster 1924 touring 1925 dump truck
Re: Model T versus Model A Valve Springs
I have seen A springs in a model T. I think they put too much pressure on the cam bearings which are much larger in an A. I use new springs and you can shim them if you want more pressure but I have not found it necessary. The valves won’t float until you are way past the rpm limits of most T engines.
Joe Bell
- First Name: Joe
- Last Name: Bell
years ago I did a valve job on a T that had crap for compression, all the exhaust valves where mushroomed out from have a heavier spring they looked like A's but might have been some thing else?? All I know once the valves and springs where changed out it ran well after?? I have asked about extra spring pressure for my Rajo and have never got an answer on that one. Hope this helps?? Joe
Erik Barrett
- First Name: Erik
Overheads want more spring pressure because the weight of the pushrods, heavier valves, and higher rpm range can all contribute to valve float.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Thanks Erik and Joe. You answered my concern.
Les Schubert
- First Name: Les
- Last Name: Schubert
I built a T engine with a really high performance A cam and the T springs float at about 4300 rpm!! So a useful built in rev limiter on a flathead T engine
