Walker hose clamps
TonyB
Topic author - Posts: 663
- First Name: Tony
- Last Name: Bowker
Walker hose clamps
I need a set of Walker hose clamps for my 1909 touring.
I spoke to Steve at Lang’s and they have none in stock and little chance of new stock. They have some of the tooling but they believe it’s incomplete.
So does anyone have details of the design so I could have a set fabricated. I looked at the picture on the Lang’s web site and I’m not quite sure how they worked.
Any information would be most appreciated.
Tony Bowker
La Mesa, California
La Mesa, California
Dropacent
- Last Name: Morsher
Doc Shanabrook- Walker hose clamps
Doc Shanabrook in Tiffin, Ohio had them made. You’re on your own to track him down. Engine Joe Bell is a friend.
Re: Walker hose clamps
Snyder's in Ohio has them listed. Given the price I'm sure some are available. I image they would lace about the same as nylon ties
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Tony, I probably have an extra set, I'll be home on Sunday night. I'll check Monday.
TonyB
- First Name: Tony
- Last Name: Bowker
As I mentioned earlier I had checked Lang’s but I had not checked Snyders. I just called and they have a set, that saves a great deal of effort. Thanks guys.
Tony Bowker
La Mesa, California
La Mesa, California
MdDWS
- First Name: Donald
- Last Name: Shanabrook
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1909
Re: Walker hose clamps story is in Vintage Ford Vol 44 No 1 Page 12to 15
The Walker clamp story is in the Vintage Ford Vol.44 No 1 pages 12 to 15
MdDWS
Re: Walker hose clamps j
Walker hose clamp story is in in Vintage Ford Magazine Vol 44 No 1 Pages 12 to 15 Don Shanabroook
ivaldes1
- First Name: Ignacio
- Last Name: Valdes
How do you keep them from leaking? I had a set of original style hose clamps but they would not get tight enough to seal so the hose leaked. I had to change to modern ones.
- First Name: Dallas
- Last Name: Landers
A bit of silicone inside with a modern clamp till its dry, then install original type. Has worked for me. Slide originals on the hose before installation.
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
What Dallas said. The silicone also makes it easier to remove the hoses when necessary. Dave
1925 mostly original coupe.
