Valve Stem
HalSched
First Name: Hal
Last Name: Schedler
* REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
Valve Stem
Post by HalSched » Wed Jul 22, 2020 8:24 pm
I just had a flat on the R F wheel. Upon opening the tire I found that the brass valve stem broke loose from the inner tube. Can a new stem be attached to the tube?
Chris Haynes
First Name: Chris
Last Name: Haynes
Re: Valve Stem
Post by Chris Haynes » Wed Jul 22, 2020 9:20 pm
That depends on the hole in the tube. If it is not torn you can simply reinstall your valve. If a new tube is needed I highly recommend those made by Blockley, https://www.blockleytyre.com/product/30x3-5-inner-tube
jsaylor
Last Name: Saylor
Re: Valve Stem
Post by jsaylor » Thu Jul 23, 2020 11:40 am
Hal, Try a metal valve stem. Steve spells it out here.
http://dauntlessgeezer.com/DG110.html
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Valve Stem
Post by Rich Bingham » Thu Jul 23, 2020 2:15 pm
The tube shown in the Blockley site has a brass stem.
So far, the 30x3” tires and tubes don’t seem to be available yet.
"Get a horse !"
Re: Valve Stem
Post by Steve Jelf » Thu Jul 23, 2020 3:05 pm
I'm sure the metal stem tubes from Blockley are excellent. But I have been buying Hartford tubes, cutting off the rubber stems, and installing my own metal stems. So far they have presented no problems. I intend for my next tyres to be Blockleys, but I will keep the Hartford tubes in them.
