Fender bender
Fender bender
Post by Dollisdad » Fri Jul 24, 2020 2:23 pm
Re: Fender bender
Post by Norman Kling » Fri Jul 24, 2020 4:14 pm
There are more bent parts than just the fenders! However, thee might be a few good parts there which, if it happened these days, would be welcome such as the gas tank in the 26-27.
Re: Fender bender
Post by DanTreace » Fri Jul 24, 2020 4:31 pm
Tried to zoom in on the turn turtle speedster. Can't tell what mods to the motor.
But the opposite rear wheel is a wire spoke, other is wood spoke, look like '26-'27 large drum? So the rear wheels mis-matched. Front are accessory wires.
Speed....ah....the devil for those wild 20's kiddos :)
Click on image to enlarge
Re: Fender bender
Post by John kuehn » Fri Jul 24, 2020 4:40 pm
Wonder what the folks looked like inside with the flying glass in the center door! The glass went somewhere! But maybe the cars parts were piled up after the wreck? Kinda looks like it was staged that way with the people standing behind it. Makes you wonder.
TFan
First Name: Jim
Last Name: Riedy
Re: Fender bender
Post by TFan » Sat Jul 25, 2020 12:06 am
That 26-27 roadster looks to have a aftermarket rumble seat conversion, you can see the step plates on the rear fender. I'd kinda like to have that. Jim
Bud Delong
First Name: Kenneth
Last Name: DeLong
Re: Fender bender
Post by Bud Delong » Sat Jul 25, 2020 8:50 am
:D Don Booth can fix the Center Door!! :D Bud.
Re: Fender bender
Post by Rich Eagle » Sat Jul 25, 2020 9:26 am
Susanne
First Name: Susanne
Last Name: Rohner
Re: Fender bender
Post by Susanne » Sat Jul 25, 2020 3:03 pm
Intake on the left, and a downdraft to boot... (at first I thought the negative was reversed, as the oil fill lools to be on the left, but the steering column corrects that assumption)...
I also can't count the number of times I've seen (even in modern accidents) where wherever the driver was got plowed by a tree, a phone pole, a concrete abutment, etc... Not sure that, if the driver stayed with it, if (or how) he would have survived that one.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Fender bender
Post by Kevin Pharis » Sat Jul 25, 2020 3:31 pm
I’ve been scratching my head over the partial engine shot too... sure looks like a spark plug and a port with a sharp vertical elbow on the left side...? This would suggest to me that we are looking at a SR Fronty...? Or maybe a Roof 8 valve...? Most likely an intake, and would not be surprised if we were looking at a copy of Ed Winfield’s 2 up 2 down high rise updraft intake...?
But then I stopped focusing in on the engine and noticed the lettering on top of the boat tail... “S•?” Could it be a proud display of the “S•R Fronty”???
Susanne
First Name: Susanne
Last Name: Rohner
Re: Fender bender
Post by Susanne » Sat Jul 25, 2020 3:54 pm
I was wondering the same thing... Could be an SR...
