Facing rode
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Facing rode
Post by D.Yoder » Mon Feb 18, 2019 12:37 pm
I made a new fixture for more accurate machining rods face.
Re: Facing rode
Post by Steve Jelf » Mon Feb 18, 2019 1:10 pm
Facing the rod is better than facing the music. :)
DLodge
First Name: Dick
Last Name: Lodge
Re: Facing rode
Post by DLodge » Mon Feb 18, 2019 1:26 pm
Or sparing the rod and running the risk of spoiling the child. :D
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Facing rode
Post by Rich Bingham » Mon Feb 18, 2019 1:35 pm
Spare rods is a good idea . . .
"Get a horse !"
RustyFords
First Name: Don
Last Name: Allen
Re: Facing rode
Post by RustyFords » Mon Feb 18, 2019 1:53 pm
Neat.
1924 Touring
Re: Facing rode
Post by Allan » Mon Feb 18, 2019 6:31 pm
Dean, do you not face the rods and caps as a pair?
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Facing rode
Post by D.Yoder » Mon Feb 18, 2019 7:47 pm
Allan, I am trying facing indexing on the rod bolt holes. More work but I think more accurate.
Re: Facing rode
Post by Allan » Mon Feb 18, 2019 10:40 pm
Dean, I presume your fixture will allow you to perform the same machining on the rod. I would be interested to know how the two match up after separate operations. A very handy old time garage owner I had the pleasure of finding some T bits for made a fixture to hold an assembled rod to a faceplate in his lathe. He'd bore the rod and chamfer/face one side in one setting, then turn the rod to machine the width and the second chamfer. My lathe is not big enough to swing a rod, or I would have a go at it.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Facing rode
Post by D.Yoder » Tue Feb 19, 2019 11:16 am
Allan, The rod and cap mate up perfectly . I set my jig for 1.490 because if the rod bolt is not perfectly perpendicular to the mating surface of the rod and cap it changes the thrust thickness. Ford specks are 1.480-1.490
