T tool at the flea market
thom
First Name: Tommy
Last Name: Coffey
* REQUIRED* Type and Year of Model Ts owned: '21 Touring
Post by thom » Sat Aug 08, 2020 4:46 pm
I found this today.
It won't work on our T though, because we have new one-piece valves without the little depressions to turn them with. For a buck I couldn't leave it behind though.
Dan B
Last Name: Blaydon
Re: T tool at the flea market
Post by Dan B » Sat Aug 08, 2020 4:59 pm
Gotta save every orphan tool.
tiredfarmer
First Name: leonard
Last Name: simunek
* REQUIRED* Type and Year of Model Ts owned: 1926 touring. 1931 model a pickup, 1947 willys cj2a
Post by tiredfarmer » Sat Aug 08, 2020 5:54 pm
It would be nice if they would put the little holes on the top of new valves.
J1MGolden
Last Name: Golden
Post by J1MGolden » Sat Aug 08, 2020 7:24 pm
Those holes were not there for valve grinding.
They were part of the manufacturing process to attach the cast valve to the machined stem.
MarkB
Last Name: Barlow
* REQUIRED* Type and Year of Model Ts owned: 1921 touring, 1911 under construction
Post by MarkB » Sat Aug 08, 2020 7:31 pm
i was using the holes to hold the valves from turning around while unscrewing the original spring retainers and the nuts on the bottoms of the 1911 valves
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Sat Aug 08, 2020 7:35 pm
Just out of curiosity why did Ford use two piece valves in the first place? It sure seems that one piece units would have been easier to make, easier to install and cheaper all the way around.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Sat Aug 08, 2020 8:28 pm
I understand it was twofold - one was it was cheaper, faster, and easier for Ford to make the valve heads separate from the round stock for the stems, less waste and faster, and the other was they could use different steels for each, to make them more durable for their different operating environments...
And I've thought about ways to add the 2 "divots" in the head of a modern valve, but I don't have the machining equipment on hand to undertake it, and if I did do that, I wonder if I wasn't making a "carbon magnet" or weakening the head...
