Why does my engine labor when I honk my magnito horn?
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Post by NorthSouth » Thu Aug 06, 2020 5:05 pm
Mark Osterman
Last Name: Osterman
Re: Why does my engine labor when I honk my magnito horn?
Post by Mark Osterman » Thu Aug 06, 2020 5:08 pm
Should be the other way around ... your horn should labor when your engines rpms are slower!
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Aug 06, 2020 6:22 pm
1- Horn has way too much amp draw.
2- Partial short between horn and switch.
3- Very weak magneto.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
* REQUIRED* Type and Year of Model Ts owned: 1916 TOURING
Post by BE_ZERO_BE » Thu Aug 06, 2020 7:28 pm
Another likely suspect - coils not up to snuff.
Respectfully Submitted,
Be_Zero_Be
I drive a Model T ... Microseconds don't matter :D
Piewagon
Last Name: Regan
* REQUIRED* Type and Year of Model Ts owned: 1911 Open Runabout, 1911 Touring, 1912 Delivery Cars (2), 1915 Roadster, 1916 Roadster, 1923 Touring Car
Post by Piewagon » Fri Aug 07, 2020 9:33 pm
OK run some tests. Either you have a weak magneto or a misadjusted horn or both. Run the car on BATTERY so that nothing is pulling from the magneto and go for a ride. The pitch of the magneto horn will change with RPM but it will sound uniformly lousy all of the time if you have it setup about right :D The correct setting for a magneto horn is that it should draw 2 amps when tested on a horn test generator but nowhere does it say what that generator is but it is NOT your T generator that is charging the battery. I would simply say that if you have a St. Louis Magneto tester you can put that on the magneto to see if you have enough output and it should be at least above or at the 1914 mark. Then put an ANALOG AC ammeter in series with the horn to see if it is exceeding the 2 amp draw allowed. Adjust it down if it is above 2 amps at any RPM. Most stock magneto horns have rusted through holes in the diaphragm and they don't work very well without a new diaphragm and a readjustment. I rebuilt mine on my 1915 and it is very loud at all speeds and does not cause the engine to stumble. It also measures just under 2 amps AC at the higher RPM It draws different amounts of current depending on whether you are going fast or slow but a good magneto will not show any lack of performance when you blow the magneto horn unless the mag horn is adjusted to draw too much current which is not good for the horn nor the magneto nor ignition.
Hope this helps.
SteveTN
Last Name: in Tennessee
* REQUIRED* Type and Year of Model Ts owned: '23 Cuttoff
Post by SteveTN » Tue Aug 11, 2020 8:58 pm
Mud dauber nest on the horn's vibrator plate.
