Pinion Bearing question
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Sat Aug 15, 2020 6:41 pm
I have the drive shaft ready for assembly. Before I do final assembly a question, the bearings sleeve is 3 1/16 but my bearing is only 2 7/8. 3/16 of play on the sleeve is correct. Don’t want to start tightening things up and set end play in not.
Mountainrider
First Name: Neil
Last Name: Haywood
Re: Pinion Bearing question
Post by Mountainrider » Sun Aug 16, 2020 6:48 am
I should have wrote, is the 3/16 of play For the roller bearing to move back and forth between pinion gear and thrust bearings correct?
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Aug 16, 2020 6:59 am
The Hyatt bearing should be able to float, drive shaft should stay still on end play in the tube.
Mountainrider
First Name: Neil
Last Name: Haywood
Post by Mountainrider » Sun Aug 16, 2020 7:26 am
Thank you.
