Cotter pins
Wwbbim
Topic author - Posts: 15
- First Name: Jace
- Last Name: Jensen
- * REQUIRED* Type and Year of Model Ts owned: 1922 Roadster
Cotter pins
Im finally finishing the rear axle and differential of my ruxlsetll but I need to know what sizes of cotter pins are used throughout the car and namely in the rear axle? Also is there different sixes of cotter pins for a ruckstell? Thanks.
- Last Name: Strange
- Board Member Since: 2013
Re: Cotter pins
The table is great, but if you didn't have the table the rule would be to use the thickest pin that will fit in the hole with enough length that the ends can be bent over. Cutting down a pin that is too long is OK.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Re: Cotter pins
The only thing I would add is that the pin needs to be a snug fit in the hole to properly keep things together. I have found that a 7/64" pin works a lot better than the Ford-standard 3/32" in 95% of the places requiring it.
R.V.Anderson
- First Name: R.V.
Re: Cotter pins
Add to the Fahnestock list, I meant.
