LED Gas headlight retrofit
jmemjr
Last Name: Memmelaar
* REQUIRED* Type and Year of Model Ts owned: 1912, 1914, 1915
Post by jmemjr » Mon Aug 31, 2020 8:05 pm
Looking for a retrofit for gas headlights to LED. Someone has made them I’m sure.
Thanks !
John
Novice
First Name: Jim
Last Name: Davis
Re: LED Gas headlight retrofit
Post by Novice » Mon Aug 31, 2020 9:52 pm
Bob. makes led replacements for the gas light. go to His 4-25-2020 835 pm post. has a lot of detailed pictures of the product. I cant get to post here.
His original post below.
Another batch of LED Lights for carbide burners just came in with longer wire leads
Post by FATMAN » Sat Apr 25, 2020 8:32 am
The leads are a lot longer and easier to run through the rubber hose, price is still the same 55.95 a pair with only 8.50 priority mail, these are selling quick, just got 20 pr. in. do not miss out
threads onto your existing burner and no modifications needed
12 volt
draws only 2 amps each
815-633-7244
modelt2001@comcast.net
Bob
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
MTFCA Number: 1575
